Riding with turn signal on
  • ckahleer
  • ckahleer's Avatar Topic Author
05 May 2026 09:07
#923690
If you don't have self canceling turn signals, it happens. I presently have 4 motorcycles and none of them have came equipped with self canceling signals. I have been expermenting with fixes and now all 4 bikes I own have different solutions.
KL600 Eliminator. Using two small springs and foam pads, converted the turn signal switch to momentary contact. this requires keeping the switch pressed, which can be difficult while manovering.
KZ305. Installed a Badlands canceling unit. Also requires converting turn signal switch to momentary contact. Signals stay on for 21 seconds, non-adjustable. $100.00
KE100 Replaced flasher with a  a beeping flasher unit. I could only find these beeping flashers in 2 pin units. Wind and engine noise make it hard to hear above 40mph. Sounds like a dump truck backing up. $10.00
TC185 Using two diods, wired a constant tone buzzer to left and right turn signals. People around me still looking for that dump truck.$10.00
I would be interested in other fixes for this issue.
1997 ZL600
94 KE100
82 KZ305
74 TC185
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Riding with turn signal on
05 May 2026 17:35 - 05 May 2026 17:36
#923718
I never really worried about it.
I usually remember to turn off my signals. but have been caught a few times not turning one off.
A riding buddy is notorious for forgetting to turn his off.
In the City I can see this being more of an issue.
I'm mostly in the Country with no one around.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 05 May 2026 17:36 by rstnick.
  • sf4t7
  • sf4t7's Avatar
05 May 2026 17:45 - 05 May 2026 17:46
#923720
I'm usually pretty good about remembering to shut off the turn signals, but every once in a while I have one of those d'oh! moments...
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 05 May 2026 17:46 by sf4t7.
The following user(s) said Thank You: slmjim+Z1BEBE
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Away
06 May 2026 07:40
#923731
If one is Ridin' behind another Rider, and sees the Rider in front drop the left hand and rhythmically open and close that hand into a fist, it's an indication your turn signal os ON.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
The following user(s) said Thank You: !Seymore
  • Cra-z1
  • Cra-z1's Avatar
07 May 2026 17:50
#923769
We have a friend who never looks in his mirrors. We can signal him for miles that we are turning so we do and there he goes off into the sunset. And if we try to catch up to him he thinks we are racing so speeds up.
When switching between a modern bike that has self canceling to the vintage bikes I sometimes forget. Now most of us have headsets and can talk to each other so we let each other know.
  • F64
  • F64's Avatar
  • 81-KZ440D2
08 May 2026 14:46
#923781
I used to have an ST2 unit and it worked for awhile but started acting strange so I pulled it.
Currently, I have super bright led's on the dash indicators for the turn signals. I guess you could also wire up another pair of bright led turn signals and aim them at your face as the led indicator bulb selection can be limited.
www.superbrightleds.com/vehicle-lights/v...rument-cluster-gauge
81-KZ440-D2.
LIC, NY
  • Zaddict
  • Zaddict's Avatar
  • Enjoying my Zaddiction!
10 May 2026 23:55
#923826
I installed a little beeper hooked up in parallel so I can hear when the signals are on. It’s good for safety, I think.
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
