Looking for a quality/loud little horn
  • ckahleer
  • ckahleer's Avatar Topic Author
30 Apr 2026 09:51
#923510
Most older bikes I pick up have poorly functioning or non-functioning horns.
What is your go to replacement horn?
I'm not looking for something big, that requires a relay, just a standard size disk horn.
1997 ZL600
94 KE100
82 KZ305
74 TC185
  • KeylAmi!
  • KeylAmi!'s Avatar
  • Engineer with ADHD
Re: Looking for a quality/loud little horn
01 May 2026 04:33
#923543
I've got a KZ700. It's got a small car horn nestled under the plastics behind the seat. I got the bike that way. It's current draw is just low enough that it doesnt seem to need a relay. I got the original disk style in a box, but they were not functioning.
Comparing to a modern bike, my horn is loud to the point of absurdity. I can try to get some specs/make/model off the horn I have, if you'd like.
Current project:
'84 KZ700
  • JR
  • JR's Avatar
01 May 2026 08:22
#923549
My original horn sounded pretty pathetic and I thought of replacing it but took it apart one day on a whim, cleaned the crud off cleaned the contacts at horn and handlebar and that made a dramatic difference.
There's not much to them.
  • Injected
  • Injected's Avatar
01 May 2026 10:22
#923560
Fiamm makes a Low Tone disc horn that is about the same diameter as a Kawasaki unit. Center mount with 2 spade connects and produces 125 dB. You can buy them at almost any place that sell automotive parts.
I believe I took one off a bike I bought so they have been around a long time. Italian build quality is pretty good.
PMC also sell a replacement disc horn, Nikko brand made in Japan that Z1 ent sells but is not as loud as the Fiamm unit at 105-110dB.
1978 KZ650B2 modified project
  • Nerdy
  • Nerdy's Avatar
  • Away
01 May 2026 13:01
#923567
I'm putting this one on the 440; it's very loud and does not require a relay. It's currently $11.55.
www.amazon.com/dp/B08HQPPTZS
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
