Coil wires
  • lovethemkzs
  • lovethemkzs's Avatar Topic Author
Coil wires
27 Apr 2026 17:36
#923397
Last year when I took the wires off the coils I remember what color went on the top and what color went on the bottom. This year I'll be damned if I can remember lol.
I was reading a couple different things some say don't matter because it was a dual plug or dual Spark I got a picture of what it said attached and it also said the yellow and green wires on the left side when I'm looking at my bike and it's on the right side so any suggestions on wiring my coils back up
  • kimchella
  • kimchella's Avatar
Re: Coil wires
27 Apr 2026 22:52
#923403
Hi, the yellow/red leads are trigger (power) from the run/off handle bar control to the coils, the green wire goes to left coil (sitting on bike) and black to right coil. These are from points or electronic ignition.
Hope this helps,
Rich.
KZ650B1 frame number 225
New Zealand
  • lovethemkzs
Re: Coil wires
27 Apr 2026 23:49
#923405
Well I'm trying to find out is it doesn't matter which wire in the group goes to the top or bottom I heard since it's a dual Spark that it doesn't matter but I want to make sure
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Coil wires
27 Apr 2026 23:58
#923406
The coil primary isn't polarity sensitive so it doesn't matter which way round the wires are on each coil
The following user(s) said Thank You: rickysnicker
  • lovethemkzs
Re: Coil wires
28 Apr 2026 03:59
#923410
I know I'm saying it wrong it was the polarity that I was concerned about and thank you again wookie I know you come through
