Trouble with ignition system...maybe.B
- F64
- 81-KZ440D2
Re: Trouble with ignition system...maybe.B
25 Apr 2026 18:06
did you set your timing with a timing light?
81-KZ440-D2.
LIC, NY
LIC, NY
- spyshot
29 Apr 2026 14:42 - 29 Apr 2026 14:43
F64 post=923343 userid=55382did you set your timing with a timing light?
no
no
1975 KZ400
Last edit: 29 Apr 2026 14:43 by spyshot.
- F64
- 81-KZ440D2
02 May 2026 12:13
I'm wondering if your timing is off causing a high idle speed.
You are trying to bring the idle speed down by richening the idle mixture.
Can you borrow a timing light?
How did you set the timing?
81-KZ440-D2.
LIC, NY
LIC, NY
- spyshot
07 May 2026 11:42I'm wondering if your timing is off causing a high idle speed.
I followed the service manual with an ohm meter. It was difficult....I'll borrow a light and report back.
Thank you.
Adam
1975 KZ400
The following user(s) said Thank You: F64
- spyshot
20 May 2026 12:40 - 20 May 2026 12:43
Thought I would update this thread. The problem was the condenser next to the points. Once replaced, problems are gone. Actually still idles a tad high but I think that is mechanical. I can push on the throttle pulley and the idle comes down. Just not sure yet what is causing it to hold open. The throttle cable has slack and the idle adjuster is all the way out.
1975 KZ400
Last edit: 20 May 2026 12:43 by spyshot.
- spyshot
20 May 2026 12:41
I did find out that the push cable is missing. I have it ordered. But, that doesn't seam like the cause of the high idle. Seams like the spring in the throttle pulley is what really pulls it back. What's the push cable for? Is it just a safety in case the throttle pulley spring breaks or gets hung up?
1975 KZ400
20 May 2026 12:47
The second cable is indeed to manually close the throttle. High idle would suggest air leaks - when you rebuilt the carbs did you remove the throttle butterflies?
- spyshot
20 May 2026 12:51 - 20 May 2026 12:53
I did not remove the butterflies. I didn't think it was necessary. Was I wrong?
I've checked over and over for air leaks.
I can put a screwdriver against the top of the throttle pulley while running and with just a little pressure can hear the idle come down and it seams to stay down. When I say high idle, by the way.... its at 1500. Not super high.
1975 KZ400
Last edit: 20 May 2026 12:53 by spyshot.
20 May 2026 14:45
No you weren’t wrong, I asked because if the butterflies aren’t adjusted correctly they won’t close fully. How have you synced the two carbs together? A good baseline is a static sync (procedure is in the manual) if you wind the idle adjuster fully off and hold the carbs up to the light is there any gaps around either of the butterflies? This is technically still an air leak as it is uncontrolled!!
- spyshot
20 May 2026 16:15
I just did the best I could to align them visually. I'll check out the manual on the static sync procedure. Thanks.
I don't understand how you do a vacuum sync, how do you get in there when the bike is running? do you rig up a temporary gas tank?
1975 KZ400
20 May 2026 16:28
Yes, to vacuum sync ideally you want the tank off and a temp set up. I have a small tank from a mower for this
- spyshot
20 May 2026 16:35
ok, back to the garage...thanks
1975 KZ400
