No spark
  • JadeDaRocker
  • JadeDaRocker's Avatar Topic Author
No spark
21 Mar 2026 18:01
#922445
Does having the start button wires disconnected stop the plugs from sparking? I had disconnected the wires because the solder points broke on the switch
1982 Kawasaki KZ750 LTD
  • hardrockminer
  • hardrockminer's Avatar
Re: No spark
21 Mar 2026 19:21
#922446
Disconnecting the starter button wires usually stops everything.
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
Re: No spark
22 Mar 2026 03:27 - 22 Mar 2026 03:36
#922450
Actually in general, the stop switch feeds battery/alternator voltage to both, the starter switch, and the coils.     The starter switch goes to a relay which fires the cranking motor, as long as button is depressed.
Of course, w/out starter switch wires, the cranking motor wont crank.
......but  once engine is running, if starter switch wires are removed, the engine should keep on running, as starter switch is open anyway if not depressed.   It is only a momentary held contact.     The stop switch in run position would continue feeding the coils and firing the sparks.    .........Am following my own wiring diagram.
Last edit: 22 Mar 2026 03:36 by hugo.
  • JadeDaRocker
Re: No spark
20 May 2026 07:07
#924092
What all would a bad ignitor cause? I can't for the life of my figure out the issue is my spark, I checked the coils and they seem fine, and I put in new plugs and wires.
  • moizeau
  • moizeau's Avatar
Re: No spark
20 May 2026 08:39
#924094
What bike is it and what have you tested up to now?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: No spark
20 May 2026 09:39
#924095
What voltage do you have at the feed side of the coils ( yellow or red normally) if you connect an LED test light across the coil terminals does it pulse when you crank the engine?
  • Injected
  • Injected's Avatar
Re: No spark
21 May 2026 08:23 - 21 May 2026 08:24
#924127
I have come across several bad Ignitor boxes on KZ650/750 models which would give a no spark situation.
First I would check for corrosion on the terminals to the box which is usually mounted under the battery box. This location sees a lot of weather so connections have to be tested. All the tests for the ignition components are covered in the FSM.
It is not uncommon to have one side of the ignition moduals to quit working but not both sides. If that is the case then the box is suspect.
You could update the system by running a Dyna S type ignition plate which has no Ignitor box.
1978 KZ650B2 modified project
Last edit: 21 May 2026 08:24 by Injected. Reason: sp
The following user(s) said Thank You: JadeDaRocker
