Starter switch problem
- JadeDaRocker
03 Sep 2025 13:47
I got the lights and everything to work but it still wouldn't start, so j took apart the switch and found this, anyway to fix this or will I need to replace it? The red wire that goes into the switch is disconnected
1982 Kawasaki KZ750 LTD
- StreetfighterKz
Re: Starter switch problem
03 Sep 2025 14:16
You can re-solder it if you have a soldering pen and a steady hand. Best bet is to pull the switch out to get more clearance from the yellow wire as you don’t want to damage it either.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: Wookie58, JadeDaRocker
03 Sep 2025 15:51
Also don’t keep the heat on for too long or you’ll loosen the contact in the housing
The following user(s) said Thank You: JadeDaRocker
