mystery wiring, KZ700
  • KeylAmi!
  • KeylAmi!'s Avatar Topic Author
  • Engineer with ADHD
03 Sep 2025 08:43
#916751
So i've been poking around behind the headlight on the KZ. And I'm finding that the wiring diagram for a KZ700 is absolutely useless. No colors match. Often, I have a different number of wires in a connector, too.
My wiring diagram shows 5 wires from the ignition switch. I have 6. Most of the wiring on this thing looks stock. So I have no idea what to reference for what goes where.
I've had a little free time lately, so I've been going through and trying to clean/replace connectors to correct for voltage drop. But an accurate wiring diagram would make it sooooo much easier.
Speaking of wiring, anyone have any good 3 slot blade style fuse holders to share a link for? I'd like to update from the old glass tubes.
Current project:
'84 KZ700
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: mystery wiring, KZ700
03 Sep 2025 11:57
#916755
How does your wiring compare with this late model 750 ?
rt22
The following user(s) said Thank You: KeylAmi!
  • KeylAmi!
04 Sep 2025 04:41 - 04 Sep 2025 05:09
#916784
how?! how did you do that? that looks like a perfect match! At least for what is behind the headlight.
did i miss some required reading somewhere?
Thank you!
Now it makes sense. I can also add the 12v accessory port I've been wanting for USB charging.
Looking at the rest of the schematic, I seem to have a blend of the two? I only have 3 fuses. This one has 5 + 2.
I have a fuel level gauge, this has a low level indicator.
Current project:
'84 KZ700
Last edit: 04 Sep 2025 05:09 by KeylAmi!.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
04 Sep 2025 05:35
#916785
Thank you!
I just guessed that a similar age 750 would be "pretty close"
  • KeylAmi!
08 Sep 2025 04:50
#916897
update:
the 1984 Z750L (non-us/canadian) wiring seems to match the best. including the extra 2-fuse holder.
is there some logic on why the 700 doesnt have 700 wiring?
Current project:
'84 KZ700
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
08 Sep 2025 05:11
#916898
update:
