Bad stator or something else?
- APrider84
27 Aug 2025 17:42
The charging system in my 75' kz400D left me stranded about a month ago. I went through the system, testing everything the best I was able. Some of the resistance measurements were a little higher than the factory shop manual listed.
The stator measured 1 ohm between all 3 coils with nothing grounding. The factory manual lists .4 - .6 ohms. I also did an AC output test at idle rpm (1200) with the field coil dead and live. The dead output was .3 - .5 volts and the live output was 3.5 - 5.5 volts. Definitely lower than I've heard it should be.
I don't have exact numbers on the field coil but it was within spec and not grounding.
The rectifier diodes measured within spec with no back flow bleed. Around 530 on all three. Im not aware of other tests i can do while not running.
The regulator tested slightly above spec on both resistance measurements. 114 on the 100 ohm spec and .6 on the .5 spec.
Im trying to figure out what I need to replace. With the regulator and rectifier both being original they are probably close to done if not already. I was thinking about a ricks electric combo reg/rec.
The stator is putting out low AC voltage from what i can tell. A new one is around $250 so i want be sure its bad before pulling the trigger.
what are your thoughts? Is anything obviously bad? Are there any additional tests i can run on the different components? Im on a pretty tight budget so i want to stick with the bare minimum initially and then upgrade other components down the road.
- APrider84
Re: Bad stator or something else?
28 Aug 2025 09:27
I will chime in since no one else is biting. Based on my research, the stator should be producing around 20 AC volts at the bare minimum. With mine making 3-5 volts, it's clearly not up to snuff. Im guessing there may be some internal shorting or resistance. The 1ohm reading on all three coils is a bit high as well. Im going to make the call that at the vety least, i need a new stator.
28 Aug 2025 10:06
You don't appear to have mentioned the ignition live to the regulator that excites the field coil (voltage check) you also don't appear to have confirmed the regulator ground is good with a voltmeter ?
- APrider84
28 Aug 2025 11:01 - 28 Aug 2025 11:02
I tested the brown 12v supply wire for the regulator and im getting 12v at the point where the wire connects to the regulator. My testing was done with the brown and green wires disconnected from the regulator and jumped so the full voltage was going to the field coil.
I do need to check the ground for the field to ensure the full voltage is flowing. Something else occurred to me regarding the stator. Im getting uneven measurements that are consistent between loaded and unloaded field coil. .05 v unloaded shows 5 v when loaded. .04v unloaded shows 4 v when loaded. .03 v unloaded shows 3v when loaded. These uneven measurements despite being consistent make me wonder if the stator has some issues regardless. Can a stator produce uneven voltage and still be good?
Last edit: 28 Aug 2025 11:02 by APrider84.
- gd4now
- Denco where did you go?
28 Aug 2025 14:05
In my way of thinking,not saying I am correct. If you have by passed the voltage regulator and provided full battery voltage to the field coil and only get the very small voltage results, I would think either the field coil or the stator is not doing it job correctly.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
28 Aug 2025 14:45
How does the field coil resistance compare to factory spec ? if the field coil isn't working correctly you won't get the required output from the stator
- APrider84
28 Aug 2025 15:46
Bypassing the regulator and jumping the brown 12v supply wire to the green wire was the procedure outlined in the kawasaki factory manual. I will double check the resistance on the field coil and also the ground circuit and report back.
I had an issue with the headlight causing a voltage drop in the brown supply wire. I fixed the ground on the headlight and that solved that issue. I did test the stator after fixing that issue to be sure it didn't change the results.
- APrider84
28 Aug 2025 18:52 - 28 Aug 2025 18:58
Field coil test results
Voltage drop at brown supply wire .3v
Generates magnetic field when charged
Resistance measures 5 ohms. Spec in the manual is 3.8 - 5.8 ohms.
Isolated the field coil and connected positive battery terminal to green wire. Measured no voltage between ground and negative battery terminal.
Measured 2.5 amps of current through the field coil
Voltage drop of .57v measured over the field coil circuit when using a dedicated ground wire for the field coil circuit.
Last edit: 28 Aug 2025 18:58 by APrider84.
- APrider84
07 Sep 2025 19:16
Update:
I bit the bullet and decided to buy a stator. I found a couple places selling new ones but both were out of stock indefinitely. After some searching on ebay and cross referencing different part numbers, i found a NOS stator that was the earlier version that got replaced with an updated one later on. The place bench tested it and said it was good. I picked it up for $160 usd + shipping.
The stator arrived on friday and after dealing with household chores for a couple days I finally had a free afternoon today. I swapped out the stator, cleaned the inside od the housing and installed a new gasket. I fired up the bike and tested the new stator. With the field coil dead it was making around 1 volt AC. With the field coil jumped to 12v, it was making around 16 volts AC at idle. I then hooked up the rectifier and regulator and tested battery voltage. Im now getting 13.5v at idle and 14.5v at 6k rpm. The original regulator was allowing voltage to reach above 15v. Im wondering if it pushed the stator too hard. I picked up a reg/rec for a cb750k that's working great.
My bike is now charging properly. I did notice a bit of corrosion on one of the stator wires so I will keep an eye on that for now.
