Right turn signal not working
- kdx200
05 Aug 2025 00:03
[object Object] I have a 1978 Kaw z400 that has working left run signals but right only stays light in back while I turn on RIGHT turn signal! SO the right turn signal bulb is burned out so I put left one in and still doesnt work! OR does ALL the light bulbs have to be in working order for BOTH turn signals to function?
Re: Right turn signal not working
05 Aug 2025 00:45[object Object] I have a 1978 Kaw z400 that has working left run signals but right only stays light in back while I turn on RIGHT turn signal! SO the right turn signal bulb is burned out so I put left one in and still doesnt work! do you have a voltmeter ? OR does ALL the light bulbs have to be in working order for BOTH turn signals to function? the front and rear bulbs have to be working for a mechanical flasher unit to function correctly however the fact that rear works would suggest the problem is "local" to the front turn signal
The following user(s) said Thank You: kdx200
