Voltage Regulator
  • seebold
  • seebold's Avatar Topic Author
Voltage Regulator
11 Jul 2025 10:33
#914568
Have 78 kz750b3. Ordered new regulator from Z1 Enterprises. New regulator has 4 wires, 2 yellow, one red, one green. Old regulator had 5 wires, 2 yellow, one red/white, one green, one brown. 2 yellows and one green are in a plug so okay there. I'm sure the red and the red/white connect to the same place. Is the green a ground, and what is the brown for? I have the factory manual but it only shows 4 wires.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Voltage Regulator
11 Jul 2025 11:27
#914573
From what you have described on the difference between the new unit and the old unit, number and color of wires, it sounds like the old unit is for an excited field system and new one for a permanent magnet system. I think the 78 model year (750 twins) is when the change happened. If what I am thinking is correct, that your mchine has an excited field system, the new unit will not work with your machine.  One quick way to see if that is the case. Look on the alternator cover (on the left hand side as you sit on the bike), are there 3 bolt heads on it. If so then your machine has the earlier excited field system
Here are some pics, yes of engine covers for the 650s but note the pic for the B1 and the 3 bolt heads the other versions do not have. This is what you would be looking for on your machine.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
11 Jul 2025 12:17
#914575
I have looked at the diagrams for B2, B3 & B4 (none Have a five wire reg/rec) red goes to red/white (battery positive) does the green go to a black/yellow at the plug ? Brown is "ignition live" which  none of the "B" series diagrams show (RR's without a brown sense system voltage internally from the battery connector (red or red/white) given the fact that the bike is 47 years old the RR you are removing may not be the original !!
PS: Out of interest why are you changing it ?
  • seebold
11 Jul 2025 16:47
#914584
Battery wouldn't charge and regulator showed a fair bit of corrosion. The connector was so old and brittle is was easy to break apart. The green wire was connected to a black ground wire someone had just shoved into the connector. Tomorrow I'm going to replace the connectors and see what I get.
  • seebold
11 Jul 2025 16:57
#914585
And this old regulator does have 5 wires. The brown wire goes to connector up under the gas tank.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
12 Jul 2025 00:13
#914593
I wasn't questioning that, simply stating none of the "B" series diagrams show it. Brow s always ignition live on Kawasaki's
  • seebold
12 Jul 2025 08:47
#914597
Agreed, my factory service manual also just shows 4 wires. Is the brown wire needed?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
12 Jul 2025 11:55
#914604
No, RR's that don't have a brown sense system voltage internally from the battery wire (red or red/white)
Just out of interest is the part number still visible on the old unit ?
  • seebold
12 Jul 2025 15:08
#914609
Looks like SH522-12. Found lots of corroded terminals, looks like the battery had cooked at some point. Not horrible corrosion but certainly enough to be an issue. Just ordered new stuff, I'll re-terminate and see where I'm at then. This bike hadn't been rode in years, have it running nicely now just need it to charge. Last thing then hopefully ready for a ride.
The following user(s) said Thank You: Wookie58, kimchella
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
13 Jul 2025 09:12
#914633
The SH522-12 (just a quick search) is for AR, KMX, KDX125, KR1S 250 and GPZ305 so I suspect at some point in the past it has been "McGyver'd"
