Removing the advancer weights/plate
- bille7
01 Jul 2025 11:59
So, one of the pickups on the DYNA S which has worked perfectly on my '80 Z1R for the last 12 years has bitten the dust. I ordered a new Dyna S, which looks slightly different
than the old/current one. Here's probably an ignorant question- how do you remove the 13mm bolt holding the advancer mechanism in, in order to install the new rotor? The bolt used to turn the
crank is 17mm and pretty thin so putting a wrench on it to hold the crank while loosening the 13mm end bolt doesn't leave enuf room for a wrench to bite. Wish I could remember
what I did last time! There are some vids on line but the ones I watched don't show removal of the bolt...
sorry abt that & thanks in advance-
bill
bill
- zed1015
Re: Removing the advancer weights/plate
01 Jul 2025 12:33
Either slim down a 17mm spanner so that it doesn't stick out further than the nut or use a 3/8ths 13mm socket that should fit inside the 17mm spanner.
Either that or just fit a 13mm ring spanner and give it a couple of sharp taps with a mallet which is what i do..
It should shift before the crank does.
- bille7
01 Jul 2025 12:54
Thanks, Zed-
Wondered if those were about the only choices. Will do-
Hope the rest of the week goes well!
b
b
- Cra-z1
01 Jul 2025 13:02
If you have the stock tool kit those wrenches are thin enough to allow a 13mm socket
- bille7
02 Jul 2025 03:39
Thanks, Cra-Z1.
I do have it but wish I could remember where I stashed it. It SHOULD be put back in the bike. It was pulled when I replaced the old glass fuse
box with something a little more modern (pictured). The relay below and to the left powers the Dyna S instead of powering it thru the kill
switch.
switch.
- slmjim+Z1BEBE
02 Jul 2025 05:19
Place tranny in 1st. gear. Apply rear brake. Crank can't rotate.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- bille7
02 Jul 2025 14:47
Just came in from test riding and saw this one. Thanks for responding. A few light taps on a box wrench end loosened it much easier than expected.
Changed the oil & filter and did a short 5 or 6 mile ride. Seems to be ok again-
thanks to everyone who replied & hope the rest of the week goes well!
cheers,
b
cheers,
b
