Removing the advancer weights/plate
- bille7
01 Jul 2025 11:15
So, one of the pickups on the DYNA S which has worked perfectly on my '80 Z1R for the last 12 years has bitten the dust. I ordered a new Dyna S, which looks slightly different
than the old/current one. Here's probably an ignorant question- how do you remove the 13mm bolt holding the advancer mechanism in, in order to install the new rotor? The bolt used to turn the
crank is 17mm and pretty thin so putting a wrench on it to hold the crank while loosening the 13mm end bolt doesn't leave enuf room for a wrench to bite. Wish I could remember
what I did last time! There are some vids on line but the ones I watched don't show removal of the bolt...
sorry abt that & thanks in advance-
bill
bill
- bound
- If you ain't HURTIN' you ain't LEARNIN'!!
Re: Removing the advancer weights/plate
25 Jul 2025 20:35
I don't know how your setup is but I always used a socket for the 13mm bolt and the 17mm wrench to hold the nut like you did. This is what worked for me when removing my timing advancer.
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
