KZ305 lights failure - where to start?
  • retka
  • retka's Avatar Topic Author
30 Jun 2025 15:37 - 30 Jun 2025 15:38
#914244
Currently working through a new to me KZ305. Going to dig out the voltmeter here in the next few days to start testing wires, but wanted to see if anyone could suggest some common areas of failure or starting places for me to look at. Unfortunately the wiring diagram is pretty blurry on the digital copy of the shop book I have so this has been part of my hesitance to dig in yet as well.
Issue: All lights are not working. Headlights, dummy lights, flashers, brake light, etc. are all non-working. The bike has a kill switch which when turned on, the bike kicks over and has spark to plugs. I haven't gotten it started as I'm also going through the entire system including a fairly rusty tank and carbs, along with replacing all the old rubber, etc. When I purchased the bike, the PO had a dead battery but jump started it using another battery via jumpers and got it running. Lights worked then but once turning on flashers, died and haven't worked since.
Things I've done so far: Replaced entire fuse box including new fuses (old one was a mess). Put in a new battery and have tested it and bike turns over easily with electric starter. The PO installed LED lights and thus had also installed a flasher relay for LEDs. I did swap to a new known working flasher relay and still nothing.
There is a very slight light that comes on for the LED headlight but otherwise when turning the key there are no changes to the bike, other than that the starter switch kicks over the starter and spark will show on a plug when put up against the case. More than wiling to do some voltage drop testing but if anyone has any ideas on where to start and/or there's some common issue these bikes suffer from, I'd love to know. Thanks for any help in advance!
1981 KZ650H1 CSR - sold
1981 KZ305 CSR (current)
Virginia
Last edit: 30 Jun 2025 15:38 by retka.
  • 82KZ305Belt
  • 82KZ305Belt's Avatar
Re: KZ305 lights failure - where to start?
30 Jun 2025 18:32
#914250
Are you looking at the pdf from this website? Its legible. If you need something better I can scan pages from my hard copy
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
The following user(s) said Thank You: retka
  • retka
01 Jul 2025 12:15
#914293
Ah good point. I totally looked over the one in the file base. Downloaded and appears legible. Going to start going through the wiring. Another old thread had a good point to check the bulbs which I hadn't considered yet. My thinking was some issue due when the bike was hooked up to the jumper battery at PO's property such as a surge. At least one of the fuses had been blown, but as stated above, a new fuse didn't solve the issue.
Virginia
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
01 Jul 2025 12:22
#914294
If you aren't fully comfortable with electrics the fault finding guide in my signature may be helpful
  • retka
01 Jul 2025 15:15 - 01 Jul 2025 15:15
#914303
Fairly comfortable with electrical. As it ended up after I traced a few things, it looks like my original thought was correct. The PO had blown all the bulbs, at least the 75% that I opened up so far that all had filaments completely destroyed/blown out. All the bulb connections seem to be getting power, so that's a relief. Ended up having to source a headlight and some new wiring for the headlight since they had put in some non-DOT LED solution from Amazon. Going to just wire in an H4 loom and use a 5.75"' LED bulb in place.
Virginia
Last edit: 01 Jul 2025 15:15 by retka.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
01 Jul 2025 15:28
#914305
Probably worth checking the charging output when it’s up and running
