Very curious - compatibility of wire harnesses for '82 1100 spectre
- Gdailey2112
- 82 KZ1100D1
11 Jun 2025 17:17
Hey gang, wiring on this bike is very age, previous owner chopped and heat fatigued, like most stockers of the same year. I'm just wondering what other years were compatible. If repairing and one has to replace a few key wires, where can I find good, color coded wiring? I'd also ordered some barrel crimps and barrel connectors.
If anyone is in the know, Wookie, F64 perhaps y'all might know this info? Please advise. Thanks
1982 KZ1100D1
Re: Very curious - compatibility of wire harnesses for '82 1100 spectre
11 Jun 2025 17:54
Partzilla shows that harness for the 1981 and 1982 CSR only, but it shows as still available.
I wonder if the LTD harness would work as the bikes were essentially identical save for the electronic speedometer and tachometer on the LTD.
11 Jun 2025 23:57I guess the answer is "how bad" is what you currently have ? any 40 year old loom from another bike is likely to have some issues with corrosion or PO "adjustments". Also a loom from a different model or "market area" is likely to have some differences. You should be able to source "most" wire colours from a good "auto electrical" supplierHey gang, wiring on this bike is very age, previous owner chopped and heat fatigued, like most stockers of the same year. I'm just wondering what other years were compatible. If repairing and one has to replace a few key wires, where can I find good, color coded wiring? I'd also ordered some barrel crimps and barrel connectors.
The following user(s) said Thank You: Gdailey2112
- H1Vindicator
12 Jun 2025 07:21 - 12 Jun 2025 08:14"Partzilla shows that harness for the 1981 and 1982 CSR only,... Ltd. ...
his motorcycle is an 1100 Spectre with different part numbers. the fsm has wiring diagrams. there's an 81-83 chain drive pdf. to see how close one of those wire harnesses would be.
Last edit: 12 Jun 2025 08:14 by H1Vindicator.
12 Jun 2025 12:37Maybe i need new readers....."Partzilla shows that harness for the 1981 and 1982 CSR only,... Ltd. ...
- Gdailey2112
- 82 KZ1100D1
16 Jun 2025 18:58
Thank ya for the info
very good info btw - as always
1982 KZ1100D1
