Turn Signal, Lights on, No Flash, Flasher OK
  • HZ-237
  • HZ-237's Avatar Topic Author
03 Jun 2025 22:00 - 04 Jun 2025 07:44
#913323
Good day all!
1985 ZX550. Turn signals will light up with the switch, but they don’t flash. Both left and right act the same. I tested the flasher with a circuit tester and it flashes the bulb.
Tried the hazards, and the right side flashes, the rear light as expected, front light almost like a flicker flash(?) and the left side doesn’t do anything. On the left, the front lights up and stays on while the rear doesn’t light up at all.
Thoughts? Could the bulbs be garbage? I’m going to try changing out the rear left bulb with an 1037 and the front right with an 1157.
Or, would this be a ground issue? If so, does anyone know where the ground is on these bikes? I’m newer to these machines and am process of getting it road worthy.
Thank you!
Last edit: 04 Jun 2025 07:44 by HZ-237. Reason: Want to subscribe so I know when there are replies.
