Ignition Coil By-Pass Trigger location on a KZ750H2
- SnyperX
18 Apr 2025 22:19
So I am working on installing the wiredgeorge ignition coil bypass mod. The documentation that wiredgeorge provided for the trigger wire does not match my 1981 KZ740H2. I am not finding a connector above my valve cover with the yellow/red wire mentioned in the documentation. Can someone that has done this be able to help me locate my trigger wire? Thanks for reading.
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
- Warren3200gt
Re: Ignition Coil By-Pass Trigger location on a KZ750H2
18 Apr 2025 23:31 - 18 Apr 2025 23:56
Wire colours are different for different bikes.
The coils each have two wires from them. Of the four coil wires two will be the same colour and go into a double bullet connector. Those two are the power to the coils.
The other two will be two different colours, likely green and black. These two are the pulse ignition wires from the ignition plate.
This is what you need to achieve.
Last edit: 18 Apr 2025 23:56 by Warren3200gt.
The following user(s) said Thank You: Gdizard, Wookie58
- H1Vindicator
19 Apr 2025 05:51 - 19 Apr 2025 05:59
the igniter connectors are probably near the battery box. possibly under the battery. there's a red power wire from the RH handlebar control to the ignition coils. that connector is probably in the headlight bucket.
in case you need a wiring diagram. from the bikenight kz750L3 page. kz.bike-night.com/media/KZ750-H2-US.jpg
Last edit: 19 Apr 2025 05:59 by H1Vindicator.
- JR
19 Apr 2025 06:58 - 19 Apr 2025 07:01
SnyperX
I`m guessing our 750 H2 wiring is same wiring as my 750E1.
Remove the gas tank and follow the follow the RH switch mini harness to where it connects with the main harness.
You can see the connector on the right in the pic below
As far as I can remember I cut the red wire on the main harness side of the connector and ran and ran wire to the relay and then wire from relay to the coil side of the cut
This is what you have
And this is what you want
Good luck
Good luck
Last edit: 19 Apr 2025 07:01 by JR. Reason: addition
- SnyperX
19 Apr 2025 10:30 - 19 Apr 2025 10:40
So my kill switch/trigger wire might be in my headlight and NOT above the valve cover? Power wire, ground, and NEW red coil wires were easy (since they come of the relay). Trigger I am not finding. I do have the colored wiring diagram I have been trying to use to locate it on the bike. Looking at the diagram the kill switch is a YELLOW wire and not a YELLOW/RED wire.
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
Last edit: 19 Apr 2025 10:40 by SnyperX.
19 Apr 2025 11:02
What colour are the positive supply wires to the coils ( these are your trigger - there should be a junction where the “ two become one”)
19 Apr 2025 11:05
NO, Yellow is the 12 V ignition input to the Kill switch, you have to connect to the (kill) switched 12 V ignition output = yellow/red wire!!!
The following user(s) said Thank You: SnyperX
- SnyperX
19 Apr 2025 11:37Left coil is red and green and right is red and black. I already made the new red wires which come off the relay. I only need to hook up the trigger which is what I can’t find.What colour are the positive supply wires to the coils ( these are your trigger - there should be a junction where the “ two become one”)
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
19 Apr 2025 11:41Disconnect the two red wires from the coils, follow them back until they join to a single red wire from the kill switch - this is then your trigger wireLeft coil is red and green and right is red and black. I already made the new red wires which come off the relay. I only need to hook up the trigger which is what I can’t find.What colour are the positive supply wires to the coils ( these are your trigger - there should be a junction where the “ two become one”)
- SnyperX
19 Apr 2025 12:57 - 19 Apr 2025 12:59And that's the issue. The wires disappear into the heavily taped factory wire loom. I would need to start slicing the tape around the wire loom and that makes me extremely nervous considering the age.Disconnect the two red wires from the coils, follow them back until they join to a single red wire from the kill switch - this is then your trigger wireLeft coil is red and green and right is red and black. I already made the new red wires which come off the relay. I only need to hook up the trigger which is what I can’t find.What colour are the positive supply wires to the coils ( these are your trigger - there should be a junction where the “ two become one”)![]()
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
Last edit: 19 Apr 2025 12:59 by SnyperX.
19 Apr 2025 13:54No problem - insulate one of the reds from the coils and use the other as your triggerAnd that's the issue. The wires disappear into the heavily taped factory wire loom. I would need to start slicing the tape around the wire loom and that makes me extremely nervous considering the age.Disconnect the two red wires from the coils, follow them back until they join to a single red wire from the kill switch - this is then your trigger wireLeft coil is red and green and right is red and black. I already made the new red wires which come off the relay. I only need to hook up the trigger which is what I can’t find.What colour are the positive supply wires to the coils ( these are your trigger - there should be a junction where the “ two become one”)![]()
- SnyperX
19 Apr 2025 14:09Went to the garage and had another look at the bike. I found a yelloe/red wire, but is part of a 6 pin connector behind the headlight. I also grabbed a pick of where the current primary coil connection come out of the wire loom. See images.No problem - insulate one of the reds from the coils and use the other as your triggerAnd that's the issue. The wires disappear into the heavily taped factory wire loom. I would need to start slicing the tape around the wire loom and that makes me extremely nervous considering the age.Disconnect the two red wires from the coils, follow them back until they join to a single red wire from the kill switch - this is then your trigger wireLeft coil is red and green and right is red and black. I already made the new red wires which come off the relay. I only need to hook up the trigger which is what I can’t find.What colour are the positive supply wires to the coils ( these are your trigger - there should be a junction where the “ two become one”)![]()
yellow/red wire
[img][img]https://i.imgur.com/4XndESMl.jpg[/img][/img]
Current coil wires from harness
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
