Headlight when cranking
  • BobZ
  • BobZ's Avatar Topic Author
18 Apr 2025 18:39
#911462
1982 750LTD  Should the headlight cut out while cranking the engine?
Had I known I'd live this long I'd have taken better care of my Led Zeppelin albums
1983 Goldwing Interstate
1982 KZ750 LTD
  • sf4t7
  • sf4t7's Avatar
Re: Headlight when cranking
19 Apr 2025 15:44
#911500
I had a couple Honda (!) Interceptors in the mid 80's (84 and an 86) and the headlight was always on when ignition was on but the headlight went out while the starter was operating, so I wouldn't be surprised if yours is the same. That was when the manufacturers added daytime running lights.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • BobZ
19 Apr 2025 17:51
#911508
Mine does not turn off when cranking the engine.  That, coupled with the fact that my starter seems weak  makes the bike not want to start when warm.  I'm getting a little over 8 volts at the coils when cranking
1982 KZ750 LTD
  • riturbo
  • riturbo's Avatar
19 Apr 2025 17:54
#911509
Mine comes on as soon as you push the starter button. Have you checked the battery, Have someone check it with a load tester if you can.
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
20 Apr 2025 01:29
#911513
What is the battery voltage when you get 8v at the coils, if you connect your voltmeter red to battery positive and black to the positive side of your coils the reading will be the difference between the two points (should be no more than 0.5v)
  • BobZ
21 Apr 2025 07:30
#911547
reading is 0.86
1982 KZ750 LTD
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
21 Apr 2025 10:17
#911558
reading is 0.86
That is too high, rather than chase your tail through several possible causes of resistance I would suggest you fit a "by-pass" relay (wired George mod) there are several threads on the topic if you use the "search" function
The following user(s) said Thank You: BobZ
  • BobZ
21 Apr 2025 13:30
#911566
I had a relay sitting around since I planned to do the mod to my old Goldwing but never got around to it.  I did the mod to the 750 today.  I didn't get a chance to get the bike up to full temp due to rain but so far it seems like it's starting easier
1982 KZ750 LTD
