Gauge restoration
  • limitfish
  • limitfish's Avatar Topic Author
Gauge restoration
05 Apr 2025 09:28 - 05 Apr 2025 09:30
#910980
Can anyone suggest someone to restore my KZ650 B1 gauges? I have been in contact with zresto but it appears they are no longer working on them. I’ve attempted to work on gauges in the past and it hasn’t turned out well. Thanks
1977 KZ650 B1 (X2)
1979 KZ650 B3
1977 KZ650 C1
1976 LTD 900
1975 H1
1984 ZX750 Turbo (GPZ)
1975 S1
1977 KE250
Last edit: 05 Apr 2025 09:30 by limitfish.
  • Nessism
  • Nessism's Avatar
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Gauge restoration
05 Apr 2025 09:55 - 06 Apr 2025 04:50
#910983
I can recommend asphalt900...he did my KZ1000A1 instruments and did a great job!
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 06 Apr 2025 04:50 by Mcdroid. Reason: clarity
  • limitfish
05 Apr 2025 09:58 - 05 Apr 2025 10:03
#910984
Thanks guys, can I message a member on here? If so I seem to have forgotten how to.
1977 KZ650 B1 (X2)
1979 KZ650 B3
1977 KZ650 C1
1976 LTD 900
1975 H1
1975 S1
1977 KE250
Last edit: 05 Apr 2025 10:03 by limitfish.
  • kimchella
  • kimchella's Avatar
05 Apr 2025 21:06
#910999
This message contains secure information
KZ650B1 frame number 225
New Zealand
  • asphalt900
  • asphalt900's Avatar
06 Apr 2025 03:04
#911003
Thanks for the Kudos fellas! Can't believe ZResto won't be working on these anymore?? Limitfish, yes i can help you with what you need. Do you still have the original ones intact? The early KZ650 B1's were unique in a couple aspects. They had a black inner can instead of green and the lens glass was concave. Send me a photo of what you have here on the forum please. Often times they were changed out because of wrecks or misbehaving over the almost 50yrs.
The following user(s) said Thank You: MFP-Joe, Gdizard
  • MFP-Joe
  • MFP-Joe's Avatar
  • forever 18 when on my bike ...!
06 Apr 2025 04:34
#911004
Clay, your detailed knowledge of the "Z", per example, in terms of instruments and handlebar switches, is great and deserves full respect!
Alway great to read about this special differences and details!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
  • asphalt900
06 Apr 2025 05:10
#911006
Well Thank-You Joe!! Actually just a byproduct of curiosity and being around soo many different bikes over the years. And a Nice reprieve from working on greasy engines, ha! Limit also if you choose to do these, note the illumination (X2 per gauge) bulb bayonet holding rubber sleeves! They are all too often hard as a rock and bits of the rubber will fall back into the gauge. They came in two basic styles. Early assemblies were separate from the wiring sub harness and merely plugged into it. Starting in around 1976 they were all one assembly. Note first two photos. Last photo is for you Joe. I make replacements for the sagging gauge needles for the KZ1300. Still don't know the upside of a lathe though, haha.
  • MFP-Joe
  • MFP-Joe's Avatar
06 Apr 2025 05:49 - 06 Apr 2025 06:10
#911008
As far as I can see, Clay, you've been doing perfectly well without a lathe so far.. ;-)Sure, it's sometimes good to have a lathe, especially if, like me, you have to make money with it... ;-)
(I have a second, small, cheap, and simple lathe right in my bike garage, so I can quickly shorten a screw or make a bushing for the motorcycles without having to drive to my workshop...( As i´ve seen on the pictures by wookie58, its the same china-type-lathe, i´ve just change the original Ø 80 mm chuck to a Ø 100 mm chuck,..and for little works it is well so far..)
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Last edit: 06 Apr 2025 06:10 by MFP-Joe.
The following user(s) said Thank You: asphalt900, Gdizard
  • asphalt900
06 Apr 2025 06:10
#911009
I leave the machining to the experts like Yourself! I could forgo toilet paper too but nice to have it. Would be beneficial to have that talent of "apparently" lots of fellas here!!
  • MFP-Joe
  • MFP-Joe's Avatar
06 Apr 2025 06:14 - 06 Apr 2025 06:29
#911010
Haha,... it's like wishing something into your right hand and shitting in your left... and seeing what happens...
No, seriously: Clay, You're talented enough!!! Go ahead with your fine work!
(( The "larger" lathe is a good precision lathe, still very precise despite its age, and with a very extensive range of accessories: 3 and 4-jaw chucks, collets from 1-20 mm, cross and longitudinal feeds...but mostly too small with a maximum diameter of 130 mm and a machining center distance of 400 mm...but I wouldn't have much desire to machine super-large diameters anyway....)
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Last edit: 06 Apr 2025 06:29 by MFP-Joe.
  • limitfish
06 Apr 2025 06:33
#911014
1977 KZ650 B1 (X2)
1979 KZ650 B3
1977 KZ650 C1
1976 LTD 900
1975 H1
1975 S1
1977 KE250
