KZ750 Horn Help
  • SnyperX
  • SnyperX's Avatar Topic Author
KZ750 Horn Help
30 Mar 2025 15:22
#910749
I continue to work on my 81 KZ750H2. Currently working on a horn issue. I had thought the horn worked initially, but doubting myself now. Headlight works, turn signals work, hazards work. I get nothing from the horn button. I swapped the horn thinking the stock was just bad and also for something a little less noticeable, but it also is not working. Took apart the left controls and blasted them with contact cleaner. Didn’t help. Fuses are all fine. What should I check next? I am so close to starting this for the first time and its the damn horn holding me up. Thanks as always.
Regards,
SnyperX
1981 KZ750H2 LTD
  • sf4t7
  • sf4t7's Avatar
Re: KZ750 Horn Help
30 Mar 2025 15:38 - 30 Mar 2025 15:39
#910751
Make sure you're getting a good ground connection from the horn control to the handle bar. On my Z1, the ground connection is through the housing body itself to the bar.  Took me a while to find the ground path!
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 30 Mar 2025 15:39 by sf4t7.
The following user(s) said Thank You: JR, Wookie58
  • SnyperX
Re: KZ750 Horn Help
30 Mar 2025 17:54
#910755
Scott, that was it!!! I ground a bit of paint off where the left controls mount and the horn now work great!!
Regards,
SnyperX
1981 KZ750H2 LTD
The following user(s) said Thank You: sf4t7, Wookie58, kimchella
  • sf4t7
  • sf4t7's Avatar
Re: KZ750 Horn Help
30 Mar 2025 20:23 - 30 Mar 2025 20:23
#910758
Turns out my 2 hours of cursing helped both of us!
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 30 Mar 2025 20:23 by sf4t7.
