1980 KZ750E wiring harness
- commotoed
- It's 1980 again!
17 Feb 2025 16:01
The wiring harness on my bike has been severely Frankensteined, and I have secured a clean, used replacement from a 1981/82. What problems do I have to look forward to?
Thanks in advance.
Thanks in advance.
Looking for 1980 KZ750E parts...
Re: 1980 KZ750E wiring harness
17 Feb 2025 17:33
There is one for $40 on eBay.
- commotoed
- It's 1980 again!
20 Feb 2025 10:57
Well, the 1st harness was supposed to have been for an 80...
- gd4now
- Denco where did you go?
20 Feb 2025 11:24 - 20 Feb 2025 11:26
I might suggest if you can find wiring diagrams for all the machines you are looking at to determine what you are facing, cause I certainly do not know the differeces. But some where not long after that it changed from points to electronic systems.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 20 Feb 2025 11:26 by gd4now.
20 Feb 2025 16:15
Also some 750,s have self cancelling turn signals and a more complex fuse arrangement on the later bkes
20 Feb 2025 16:41
For 1981 Kawasaki added the Reserve Lighting System and a Low Fuel Warning Light to the 750E2.
1980 750E has a volt meter, and a slightly different warning light setup.
It shouldn't be too hard to adapt the harness between models. I suggest laying out the harnesses on a large table, and noting differences.
- H1Vindicator
21 Feb 2025 09:42Afaik. all 1980-on 750-4s had electronic ignition. wiring diagrams. kz750L3 page with diagrams for most of the 80-84 models. kz.bike-night.com/manual.htmlI might suggest if you can find wiring diagrams for all the machines you are looking at to determine what you are facing, cause I certainly do not know the differeces. But some where not long after that it changed from points to electronic systems.
The following user(s) said Thank You: philmountains
