LED taillight (kz400)
29 Jun 2024 16:43 #901510 by ThatYeti
Replied by ThatYeti on topic LED taillight (kz400)
I'm sure you're right about all that, but also it seems like the bike may have been missing the switch when it came to me. Per the manual I think it's supposed to be here. Also finished wiring the rear blinkers and unlike when I just had the right side on and they were working as expected...now I get all four going when I hit the signal no matter which direction....
'76 KZ400
30 Jun 2024 01:31 #901521 by Wookie58
Replied by Wookie58 on topic LED taillight (kz400)
You are looking in the wrong place at the wrong thing, the below picture you posted has the answer for you !!!!!!!
Ref the turn signals, you have a single warning light so will need to install "diodes" in the wires to the warning light (Scirocco has previously posted a diagram for this)
The following user(s) said Thank You: ThatYeti
30 Jun 2024 04:02 - 30 Jun 2024 04:08 #901523 by ThatYeti
Thanks and so I should add the resistor to the circuit? They came with tap connectors and I'm a bit leery of using of as I'm worried they'll ruin the wiring and doing some searching it seems they may not be a great solution. Also I've no idea what's in that photo, I pulled it from the manual posted online and can't make out where on the bike it is or what is in the pic that's helpful.
Also what's missing that's meant to plug into the brake fluid reservoir?
'76 KZ400
Last edit: 30 Jun 2024 04:08 by ThatYeti.
30 Jun 2024 07:04 #901528 by Wookie58
No resistors, I will try later and sort a diagram for the "diodes" for the turn signal warning
Does the brake light work when you pull the handlebar lever? (If so nothing is missing)
30 Jun 2024 09:31 #901532 by ThatYeti
Thanks, cause I'm not understanding otherwise. Also it seems this likely needed something plugged into it but can't find anything in the manual.
'76 KZ400
30 Jun 2024 10:47 #901535 by Wookie58
Does the brake light work from the lever ? (that is the brake light switch and should have 2 wires from the switch loom to plug into it unless it has a pressure switch in the brake line)
30 Jun 2024 10:57 #901537 by ThatYeti
Believe so but will have to confirm later. Can see the brown and blue wires that I believe are meant to go to it go under the backside of the tank but can't see where they end up and didn't have time to pull the tank last night.
'76 KZ400
30 Jun 2024 11:41 #901543 by Wookie58
30 Jun 2024 11:54 - 30 Jun 2024 12:05 #901545 by TexasKZ
Replied by TexasKZ on topic LED taillight (kz400)
I am about 83% sure that all of the disc brake equippped KZ400s, except the 1979 KZ400H, had a pressure switch on the splitter. The 1979 KZ400H and the later KZ440s had the pressure switch on the master cylinder.
Your signature line says yours is a 1976. Since it has a front disc brake, it would be a KZ400D, which should have a master cylinder with a round reservoir, and a pressure switch on the splitter.
www.partzilla.com/catalog/kawasaki/motor...cylinder-76-77-kz400
Evidently, yours has a later model master cylinder from a KZ400H, or a KZ440, with what is now a redundant pressure switch.
Last edit: 30 Jun 2024 12:05 by TexasKZ.
The following user(s) said Thank You: Wookie58, ThatYeti
30 Jun 2024 13:06 #901552 by ThatYeti
Thanks and seems that will probably solve the blinker issue but why didn't it happen when I swapped the front set? Or when I had one of the two rears installed?
'76 KZ400
30 Jun 2024 13:09 #901553 by ThatYeti
Believe you're right that it's a kz400D, as it's got the disc brake and electric start. Bike definitely wasn't 100% original when I got it but pretty close so maybe that was already swapped? Is that something I need to replace to fix this problem?
'76 KZ400
30 Jun 2024 13:12 - 30 Jun 2024 13:14 #901554 by Wookie58
While there was still an incandescent bulb in either side the warning light had a path to ground through the bulb on the opposite side. Because an LED will illuminate on a smaller voltage that path to ground also illuminates the opposing lamp
Last edit: 30 Jun 2024 13:14 by Wookie58.
