- Thank you received: 2395
LED taillight (kz400)
25 Jun 2024 01:20 #901282
by Wookie58
Replied by Wookie58 on topic LED taillight (kz400)
If you have wired it as per the below then the brake light should be brighter than the tail light. I would suggest checking with a voltmeter that you have power on the brake light feed (I know you say the old light works ok) if you have voltage on the blue brake light feed and everything else is wired correctly the lamp unit is probably faulty
The following user(s) said Thank You: ThatYeti
- ThatYeti
- Thank you received: 14
25 Jun 2024 04:51 #901288
by ThatYeti
'76 KZ400
Replied by ThatYeti on topic LED taillight (kz400)
Tried wiring it like that without any success. My money is on the light being bad but have the resistors coming today just to see if that'll help. If not I guess I'll order another of those lights and hope for better luck unless you have a link to the one you used.
'76 KZ400
25 Jun 2024 05:00 #901289
by Wookie58
To be honest if you have the required voltage on the right wire at the right time it only really leaved the lamp unit (I guess at $10 bucks a pop the "quality control" is probably not great )Tried wiring it like that without any success. My money is on the light being bad but have the resistors coming today just to see if that'll help. If not I guess I'll order another of those lights and hope for better luck unless you have a link to the one you used.
- ThatYeti
25 Jun 2024 05:46 #901292
by ThatYeti
'76 KZ400
Ya that's what I'm thinking, reordered another of those lights so if the resistor doesn't help, fingers crossed another light will do it.
'76 KZ400
- ThatYeti
25 Jun 2024 20:07 #901347
by ThatYeti
'76 KZ400
Ok, so I had the thing wired up loose and got it to work, showed the running light with the key on and flashed brighter with the lever and but the stop light on the dash was still flashing. Figured I'd just pull the bulb so went on making a bracket for the light, wired it up for solidly...and now I get no running lights no matter what and I can get the dash light to stop flashing with the resistor and brake light works fine. No idea how or why but hoping that mess makes sense to someone else.
'76 KZ400
25 Jun 2024 22:49 #901349
by Wookie58
If this is the final version of your wiring I'm not surprised you are having issues, you need to cut that white plug off the light wiring and replace with insulated bullets that will connect to the bikes harness
- ThatYeti
26 Jun 2024 03:52 #901360
by ThatYeti
'76 KZ400
Thanks and no, that was just my attempt to confirm it was all working before I crimped it all and found a spot to hide the wires. Had found a matching harness plug to mate with the one the light has but I think I may just match the factory bullets instead as the whole harness plug I got doesn't inspire a lot of confidence. All that said, why wouldn't I get the same results so long as everything is making contact?
'76 KZ400
26 Jun 2024 04:10 #901361
by Wookie58
You need to hook up a voltmeter and see if there is power to the light unit when it isn't working
- ThatYeti
26 Jun 2024 05:08 #901363
by ThatYeti
'76 KZ400
Can't recall if it's with or without the resistor attached but you can see it strobe faintly when it should be showing the running lights solid, so I'd say it definitely has power.
'76 KZ400
26 Jun 2024 06:07 #901364
by Wookie58
The question is "how much" an LED will glow with 2v, the only way to take the guess work out of electrical diagnosis is with a voltmeterCan't recall if it's with or without the resistor attached but you can see it strobe faintly when it should be showing the running lights solid, so I'd say it definitely has power.
- ThatYeti
26 Jun 2024 17:15 - 26 Jun 2024 17:27 #901388
by ThatYeti
'76 KZ400
Pulled the connector off and tried wiring them right into the bullets with the new light that came today. Got it to show brake lights at first, but won't light up any more after trying the resistor a few different ways. Also took the new light and pressed the connectors into the clamps on a car jump pack battery and they lit up as expected. What would I check with the volt meter and how would I do it?
'76 KZ400
Last edit: 26 Jun 2024 17:27 by ThatYeti.
- Thank you received: 2086
26 Jun 2024 17:39 #901389
by Scirocco
Replied by Scirocco on topic LED taillight (kz400)
Your connections looks like the "Gordian knot", OMG
