Front turn signals stay open
  • Fox
  • Fox's Avatar Topic Author
30 May 2024 11:45
#900018
Hello,
i'm putting the oem front turn signal on the kz1000 ltd 77. But they stay open. Trun signal and warning work.
one the right side i have :
blue to blue
grey to grey
black to yellow/black
On the left side
blue to blue
gray to green
black to yellow black
I must be good but the light stay on like the headlight...
Do you have an idea ?
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Front turn signals stay open
30 May 2024 13:36
#900019
Do they flash when you operate the turn signal?
are they staying on full brightness?
do you have twin filament bulbs fitted (stop and tail bulbs)?
do you have a two position light switch on the right handlebar switch?
The following user(s) said Thank You: Fox
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
30 May 2024 13:37 - 30 May 2024 13:43
#900020
I have no problem saying I know more about the 650s than I do the 900/1000 bikes from that year. But I think the 77 1000s had running lights on the front so they should be on when the head light is on. As to blinkers there are switches and flasher that get involved.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 30 May 2024 13:43 by gd4now.
  • Fox
30 May 2024 16:49
#900023
Yes the front lights sould be on but not bright i think ... more amber.
Here they are very bright and the flasher and bliker just "cut the light" when they are on.
2 filament bulbs. A 2 switch position light..
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • F64
  • F64's Avatar
  • 81-KZ440D2
30 May 2024 21:42
#900029
I wonder if the bulb is plugged in backwards. You can plug the bulb in backwards if you push down hard enough.
Your bright filament will be on all of the time and the low filament will blink.
Either that or the bulb is the wrong type and the high/low filaments are reversed inside.
81-KZ440-D2.
LIC, NY
The following user(s) said Thank You: Fox, Wookie58
  • Fox
31 May 2024 08:11
#900053
I will check that
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
