Sh 775 regulator rectifier info
- patterst
28 May 2024 15:15
1983 kz 1100 ltd
I've been reading through a bunch of posts on here regarding the shindengen sh 775 r/r unit. I see that id clip the connector from the stator and run those wires directly to the r/r. What I'm not clear on is the other connector on the sh 775 - what is getting connected there or rather, where do the lines from that side go to? Also, after removing the stock r/r, im confused on what I need to do with the now unused connection - am I pulling any wires from here to go to the new r/r?
Re: Sh 775 regulator rectifier info
28 May 2024 15:46
So the three yellows from the stator connect to the new RR
The red/white connects to the red on the new RR (+)
The black/yellow connects to the black from the new RR (-)
The brown is no longer required (make sure it is insulated as it links to a main ignition live
28 May 2024 18:41 - 28 May 2024 18:41
Be careful buying a SH775, there are lots of fakes in the marketplace. Be sure to look at the top fin, and make sure you can see the SH775 printing.
Triumph sells a great adapter harness...for cheap.
This is how I wire mine. This wiring is taylored for a Suzuki GS, but I think most KZ's are similar.
SH775 Install
by
nessism
, on Flickr
Last edit: 28 May 2024 18:41 by Nessism.
The following user(s) said Thank You: SWest, Mikaw, Wookie58
28 May 2024 18:48Nessism, do you know the Triumph part#?Be careful buying a SH775, there are lots of fakes in the marketplace. Be sure to look at the top fin, and make sure you can see the SH775 printing.
SH775 Install by nessism , on Flickr
28 May 2024 20:17
PN T2500676 Harness
The following user(s) said Thank You: Scirocco
- Injected
29 May 2024 06:28 - 29 May 2024 06:29
I fit one on my KZ650, I used some cheap plugs you can buy on Ebay using the Triumph PN.
Its a tight fit on the 650 and just fits under the side cover. I only needed to slot one hole on the electrical bracket to mount it.
This one was bought used, originally for a Polaris ATV.
1978 KZ650B2 modified project
Last edit: 29 May 2024 06:29 by Injected. Reason: info
- patterst
29 May 2024 17:15 - 30 May 2024 00:54
I'm a bit confused on where I'm clipping to get the wiring to the 775. Attaching a pic of my connectors- hoping someone can say which connector I can clip from and on what side of the connector (if it makes a difference). I'm assuming I'm clipping from the reg/rec connector but wanting to confirm before I go clipping away
Last edit: 30 May 2024 00:54 by Wookie58. Reason: Adding to post
30 May 2024 01:01
- patterst
30 May 2024 13:47
Dude, I appreciate you so much. Prolly seems like a stupid question, and it was making sense in my mind to do it that way, but from the bits and pieces I was reading on different posts about the sh 775, I was second guessing myself left and right. Thank you so very much!
The following user(s) said Thank You: Gdizard, Wookie58
- referman
30 May 2024 17:25
I got mine from
Roadstercycle
. works great and you can also get the wiring.
1980 KZ1000 MKII
1075cc
Ported head
Mikuni Rs36
Cam Motion Z4
Falicon Crank
2022 Z900 RS 50TH Anniversary
1075cc
Ported head
Mikuni Rs36
Cam Motion Z4
Falicon Crank
