KZP key
KZP key
20 May 2024 08:27
How do I get a key for a 94 KZP. Where can I find the numbers? They said they tried to start the bike and the PO said it was running great but overcharging then the key was lost. They haven't munged up the switch
Re: KZP key
20 May 2024 08:42
If it's the same as the "J" "K" and "M" then the key number is on the body of the ignition switch. Once you have the number you can order a replacement key
Re: KZP key
20 May 2024 15:45 - 20 May 2024 15:46
The key code may be stamped into the seat lock as well. I don't know which would be easier to get at to see the code.
Also in case you aren't aware, the 1000P police bikes have have a replaceable key lock cylinder for the fuel tank.
1994 KZ1000-P13 Ignition switch & locks >> www.partzilla.com/catalog/kawasaki/motor...tch-locks-reflectors
1994 KZ1000-P13 fuel tank >> www.partzilla.com/catalog/kawasaki/motor...kz1000-p13/fuel-tank
Last edit: 20 May 2024 15:46 by martin_csr.
Re: KZP key
20 May 2024 15:51On the lock set from my "K" that I sent to Carlos it was only clearly visible on the ignition lock, the seat lock had a shorter number (4 not 5 digits)The key code may be stamped into the seat lock as well. I don't know which would be easier to get at to see the code.
Re: KZP key
20 May 2024 17:56
I was going to suggest the seat lock, but didn’t know for sure if the c/p had one. Should be on the steering head lock again IF that bike has said locking.
