Am I able to check electronic systems without engine?
  • Buschpush
  • Buschpush's Avatar Topic Author
  • Forgive me if I sound dumb, new to this
19 May 2024 07:12
#899293
Am I able to check the electronic system without the engine in the chassis? I got told that if I wrap up all the mounts and connections to the engine and make sure they're not touching that I can do so. I'm just double-checking.
 I have a kz250G LTD 1981
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Am I able to check electronic systems without engine?
19 May 2024 13:08
#899312
It is potentially possible if you are careful but largely pointless. To test electrical circuits properly they need to be all plugged in and powered up
The following user(s) said Thank You: Buschpush
