Multi function switches on a 1979 mkII
  • jsignaigo91
  • jsignaigo91's Avatar Topic Author
13 May 2024 04:59
#898938
Has anyone dealt with these multifunciton switches?
www.amazon.com/dp/B07NBVR8DS/?coliid=I4T...c_wl_lv_ov_lig_dp_it
z1 parts has what looks like the identical set. Im wanting to put them on a 1979 MKII. They look very similar if not identical to the ones that are on the bike im wondering if the wiring is different some where?
  • martin_csr
  • martin_csr's Avatar
Re: Multi function switches on a 1979 mkII
14 May 2024 06:28
#898991
There may be a KZ900 wiring diagram in the Filebase here on KZR, for comparing to the MKII wiring.  I'm assuming you have a wiring diagram for your motorcycle.  I'd guess you'll have to do some rearranging of some of the wires. just a guess.
  • hardrockminer
  • hardrockminer's Avatar
14 May 2024 12:27
#899018
If those are for a KZ900 they may not work on a MK2.  But you can check Partzilla to see if the part number is the same.  If not...you pays your money and takes your chances.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
14 May 2024 13:22
#899025
If you decide to run with them (if you can't find the right ones) I can help you with the wiring
  • jwfels
  • jwfels's Avatar
14 May 2024 15:06
#899040
Hi, installed a 900 switch on my 81 650, wanted switched lighting, 900 switch has a 4 pin connector, kill switch and starter, plus a blue wire with a bullet duplex end-light switch feed, you probably have always on lighting, it will work, 650 has a 6 pin connector, when light switched was eliminated, wiring for lights is still in switch harness,and spliced under sleeve, as yours might also, relocate wires to old plug in proper locations, new blue will have to go into old plug, and you will have switched lighting also now, kill switch is also 90 degrees different
Z1A AND 81 650
  • jsignaigo91
19 May 2024 19:56
#899343
I do have a wiring diagrams for the mkII but thank you for offering. Thats intrestsing jwfels. Thank you for the input. Im fine with that outcome then.
