Installing a LED H4 bulb will it fit/work??
  • Mikaw
  • Mikaw's Avatar
Re: Installing a LED H4 bulb will it fit/work??
11 May 2024 11:44
#898888
Slmjim, appreciate the request for information, otherwise I might have never looked. The H4 housing/shell is labeled CPI. It has a Fresnel type pattern in a semi triangle shape extending from the center logo towards the right (left from drivers orientation). It is marked Motorcycle also as you mentioned.
The following user(s) said Thank You: slmjim+Z1BEBE, Nessism
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
12 May 2024 05:43
#898919
Yep, that's it.  Thanks for the response.  And, when we wrote 'right'  we meant the other right... .  That pie-shaped portion is left-side beam cutoff.
We've upgraded all our Z1's to that CPI H4 halogen headlight assy. over the years & saved working sealed beam headlights for shows if desired or box-stock necessity (looking at you, Barber).  The CPI's work fine with standard 60/55W H4 bulbs when aimed right, and H4's are ubiquitous, very robust & cheap.   The original Stanley sealed beam units that were OEM on Z1's, that also still have both filaments working seem to be made of increasingly-expensive unobtanium these days.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
  • Mikaw
  • Mikaw's Avatar
12 May 2024 15:53
#898931
Slmjim, your welcome and great minds think alike.
