Cheap tachometer
- ckahleer
Cheap tachometer
21 Mar 2024 18:31
Has anyone had any luck using those cheap techometers they sell on e-bay for around $10. The type you wrap a few turns of wire around a spark plug lead.
I bought one to do some testing on my KE100, but the readings are all over the place.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
- asphalt900
Re: Cheap tachometer
22 Mar 2024 03:47
Probably trying to read at real time, no delay built-in, if that makes sense. I have a "Tiny-Tach i've had for years but think they are about 70USD. They have circuitry that buffers that induction signal you're getting at the high tension wire. Stabilizing the display LCD.
- asphalt900
22 Mar 2024 04:43
That's why i stick with my old analog meter style, can't beat it for simplicity.
