What is the best way to buy pulsing coil for GPz?
- chopper1963
19 Feb 2024 13:51
I'm looking for a pulsing coil set up for my 1981 D1 that will plug into the harness. Isn't there a firm making new ones or am I thinking of the other side of the engine?
It's part number 59026-1009.
Suggestions welcome.
Re: What is the best way to buy pulsing coil for GPz?
19 Feb 2024 14:48 - 19 Feb 2024 14:48
https
/www.ebay.com/itm/335177355707
remove extra spaces
/www.ebay.com/itm/335177355707remove extra spaces
Last edit: 19 Feb 2024 14:48 by Nessism.
19 Feb 2024 14:49
Seems to be a few available on eBay, not cheap though !! Why are you replacing them ?
- chopper1963
19 Feb 2024 15:00
Not replacing. Missing.
Doing a ground-up on a 1981 GPz550. I can see the end of the tunnel --or is that the bright lights at the end of life?. This was one of the "find it later" list a year ago.
I cobbed some stuff off my KZ700 parts bike but that part of the 700 isn't going to work.
- chopper1963
19 Feb 2024 15:01 - 19 Feb 2024 16:14
Ness!
Thank you. Man that is spendy but if I have no choice.
Say--thanks for all your posts here and help. I'd buy you lunch if you were local.
I've got a bunch of KZ and GPzs. You have been a big help.
Last edit: 19 Feb 2024 16:14 by chopper1963.
20 Feb 2024 06:38 - 20 Feb 2024 06:44
From the diagrams at Partzilla it looks like all of the KZ550s w electronic ignition used the same pulsing coil.
There's an ebayy parts lot for a KZ550C that includes the needed part plus a timing advancer. #266357158260. $135T.
The pulsing coil looks to be in good physical condition but used part, so you never know.
Last edit: 20 Feb 2024 06:44 by martin_csr.
- howardhb
- God, I trust
20 Feb 2024 22:07 - 20 Feb 2024 22:28
I bought this CALTRIC pick-up (search item 293337737915) form my GPz 550 D1 from Ebay for $25 .
Works a treat!
H.
Works a treat!
H.
'81 GPz 550 D1
'82 Yamaha YB100 Fizzie
Last edit: 20 Feb 2024 22:28 by howardhb.
