Plastic for electrical contacts -74 Z1 900
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: Plastic for electrical contacts -74 Z1 900
10 Feb 2024 05:28
#895071
What is this contact type called, a male and a female part?
Male.  Nomenclature follows the conducting pins in this case.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
  • Mikaw
  • Mikaw's Avatar
10 Feb 2024 07:46
#895076
Maybe some more information would help. What are you attempting,
  • Building your own harness?
  • Repairing your existing?
You would be surprised how durable the OEM connectors. Look for harness that have connectors with bright colors, and examine them closely to make sure the locking tabs are intact. Another reason for repurposing an old harness is, to date I don’t think any member here has found the replacement bullet terminals to go in the connector. You may have to cut the connector off intact with short leads of wires and solder and shrink wrap that unit to your existing harness.
  • Mikaw
  • Mikaw's Avatar
10 Feb 2024 08:22 - 10 Feb 2024 08:35
#895078
PMC, (Performance Motorcycle Creative) sold or maybe owned by Webike in Japan sells replacement harnesses. It’s possibly you my be able to track down a contact for customer service and send an email. Here is a replacement stator harness sold by Webike branded as PMC. It has the blue 6 pin you’re looking for. I have minimal experience with the aftermarket harnesses but I don’t remember the new locking into the OE. Your best bet to match your new center harness would be aftermarket connectors.
japan.webike.net/products/1522038.html
Heres a contact email for Webike This email address is being protected from spambots. You need JavaScript enabled to view it.
Last edit: 10 Feb 2024 08:35 by Mikaw.
  • increasing
  • increasing's Avatar Topic Author
  • curious to know
10 Feb 2024 08:54
#895080
I am in the process of replacing large parts of the electrical wiring and am using parts from PMC. Stator cable with blue connector linked to her I will buy, brown connector is on the main cable package. Then I only need a white and green contact, but I had hoped I could avoid buying everything except the contact itself.
White
www.cmsnl.com/kawasaki-z1-1973-usa-canad.../rectifier_21061019/
Green
www.z-power.co.uk/regulatorrectifier-z1-900
increasing :)
1974 Kawasaki Z1A 900, 1976 Kawasaki KZ900-A4, 1987 Kawasaki GPX750R
  • martin_csr
  • martin_csr's Avatar
12 Feb 2024 06:06
#895154
What're the chances the connectors could be 3D printed?
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
12 Feb 2024 09:36
#895156
I don't see it listed, but I would contact this site and see if they can help.  At least they may be able to tell you the manufacturer and part family.
www.cycleterminal.com/motorcycle-connectors.html
My dad's '74 Z1
'00 ZRX1100
  • Mikaw
  • Mikaw's Avatar
12 Feb 2024 10:12
#895158
Great Mind’s think alike. I emailed them about this Saturday but haven’t seen a reply yet.
  • sf4t7
  • sf4t7's Avatar
12 Feb 2024 10:14
#895159
+1 on cycleterminals.com.  Quality stuff.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • Mikaw
  • Mikaw's Avatar
12 Feb 2024 21:23 - 12 Feb 2024 21:25
#895192
Cycle terminal responded. They think it is a Mitsubishi connector, using PYC style terminals. This is as close as I get so far.
I have a few more emails out waiting on responses.
Last edit: 12 Feb 2024 21:25 by Mikaw.
  • slmjim+Z1BEBE
13 Feb 2024 05:50
#895206
Check our last post in this thread for pin & pin housing info.
www.kzrider.com/forum/4-electrical/619629-crimp-replacements
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
