Plastic for electrical contacts -74 Z1 900
  • increasing
  • increasing's Avatar Topic Author
  • curious to know
09 Feb 2024 12:29 - 09 Feb 2024 12:32
#895037
Can you buy just the plastic for these, in the colors brown white green blue ... for 1974 Z1 900
increasing :)
1974 Kawasaki Z1A 900, 1976 Kawasaki KZ900-A4, 1987 Kawasaki GPX750R
Last edit: 09 Feb 2024 12:32 by increasing.
  • Mikaw
  • Mikaw's Avatar
Re: Plastic for electrical contacts -74 Z1 900
09 Feb 2024 15:35
#895041
Buy a cheep old harness and get some pin release tools to remove them. I have not seen new ones, but would be interested if there available.
  • sf4t7
  • sf4t7's Avatar
09 Feb 2024 19:30 - 09 Feb 2024 19:39
#895050
Found using google - Motomentum has a 2Fast moto reproduction center wiring harness p/n 26002-035 for not much money.
edit: oops looks like you need the male plug end, harness I found has female plug.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 09 Feb 2024 19:39 by sf4t7.
  • Mikaw
  • Mikaw's Avatar
09 Feb 2024 19:45
#895051
Having a second look you’ve posted an aftermarket center harness. The connectors have a transparent appearance and the green insulator on the terminal is too green.
  • sf4t7
  • sf4t7's Avatar
09 Feb 2024 19:49
#895053
Just tryin' to help - I did call it "reproduction"
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • Mikaw
  • Mikaw's Avatar
09 Feb 2024 19:52
#895054
No, not your post. The OP.
  • increasing
  • curious to know
10 Feb 2024 00:06 - 10 Feb 2024 00:09
#895055
@Mikaw  Thanks, good advice but they will probably be bad and brittle in the plastic like my old ones.
increasing :)
Last edit: 10 Feb 2024 00:09 by increasing.
  • increasing
  • curious to know
10 Feb 2024 00:15 - 10 Feb 2024 00:21
#895056
I have a new wiring harness including the part as @sf4t7 posted 26002-035 What I need are the plastic plugs that go on the four. A blue, white, yellow and brown connector.
increasing :)
Last edit: 10 Feb 2024 00:21 by increasing.
  • Warren3200gt
  • Warren3200gt's Avatar
10 Feb 2024 00:35 - 10 Feb 2024 00:43
#895058
Last edit: 10 Feb 2024 00:43 by Warren3200gt.
  • increasing
  • curious to know
10 Feb 2024 00:36
#895059
I may have explained myself poorly, what I want to buy are the 4 connectors to be plugged into the Center Wiring Harness which I am attaching a picture of here.
increasing :)
  • increasing
  • curious to know
10 Feb 2024 02:54
#895062
Thanks @Warren3200gt … looked at the page but I don't see 6 pins with round pins
increasing :)
  • increasing
  • curious to know
10 Feb 2024 03:28
#895066
What is this contact type called, a male and a female part?
increasing :)
