Starter solenoid/fuse wiring
- NoKnows
20 Jan 2024 13:34 - 20 Jan 2024 13:35
Hello, could someone with a 1981 kz550 send a pic of how there fuse and starter solenoid is hooked up. or any help on how this gets hooked up would be much appreciated.
Last edit: 20 Jan 2024 13:35 by NoKnows.
Re: Starter solenoid/fuse wiring
21 Jan 2024 06:25 - 21 Jan 2024 06:26
What 550 model is it? Ltd, A, or GPz.
For bare bones wiring here's a topic with diagrams by loudhvx. page linked has a diagram for an 81 KZ550-C2:
kzrider.com/forum/4-electrical/172746-19...t?limit=20&start=320
The loudhvx motorcycle stuff page has a lot of info for the KZ550, including a number of stock wiring diagrams.
s3.amazonaws.com/gpzweb/index.html#home
The parts diagrams at Kawasaki.com or Partzilla may give clues to how things should be bolted and oriented on the motorcycle.
www.partzilla.com/catalog/kawasaki/motorcycle
Last edit: 21 Jan 2024 06:26 by martin_csr.
- NoKnows
21 Jan 2024 07:17
The only information i have about what model 550 it could be is the engine number which doesnt match any of the models from 82-83 (KZ550AE041350).
21 Jan 2024 20:04 - 21 Jan 2024 20:26
1982 550A or 550C.
Their engine numbers began with KZ550AE035401. The 1983 models began with 055501.
The frame number, stamped on the steering head, will tell the year and model designation. There should also be a decal there with the number and date of manufacture printed on it. Keep in mind that the 1982 models were produced from late July or early August 1981 through that same time in 1982.
See pages 68 - 69 for some of the differences between the A and C. www.kzrider.com/modules/ServiceManuals/M...nition_1982-1985.pdf
Last edit: 21 Jan 2024 20:26 by TexasKZ.
