GPZ 750 Unitrack MotoGadget Blue
- Erikwolf22
06 Jan 2024 11:48 - 06 Jan 2024 14:07
Hi members!
As shortly adressed in my " introduction topic" I am working on a custom bike based on a GPZ 750 Unitrack from 1983 and so far this forum helped me with a lot of things. Many thanks for that!
But now I'm installing a Mo.Unitt bluetooth on my bike I do run into a couple of problems connecting the reg-rec and ignition and I hope some of fyou can give me some guidance or advice.
Reg-rec (original OEM for the GPZ).
I do have 2 cables left that I am not sure on what to connect.
1x Brown-White
1x Yellow-Black.
I do expect that one of them needs to be connected to the Mo.Unit, but I can't figure out which one it is.
Ignitor (original OEM from the GPZ)
I do have 3 cables left. One of them should probably got to the Mo.Unit, one to ground and one to an interlock system.
1x Black
1x Yellow-Black
1x Black-white
Any help is gratly appreciated!
1x Brown-White
1x Yellow-Black.
1x Black
1x Yellow-Black
1x Black-white
Last edit: 06 Jan 2024 14:07 by Street Fighter LTD.
Re: GPZ 750 Unitrack MotoGadget Blue
06 Jan 2024 14:08
Welcome
I fixed your attachments to be full size . Next time click the insert all tab to complete the install
The following user(s) said Thank You: Erikwolf22
- Erikwolf22
- Injected
12 Jan 2024 13:13 - 12 Jan 2024 13:16
Black/Yellow wire is always to ground on a Kawasaki harness. Brown wire on RR is voltage sense.
These may help :
These may help :
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 12 Jan 2024 13:16 by Injected. Reason: pic
- F64
- 81-KZ440D2
12 Jan 2024 16:25
Reg Rec does not need to be connected to the m-unit.
Just run your red coil wire to the ignition output on the m-unit.
81-KZ440-D2.
LIC, NY
LIC, NY
- jwfels
13 Jan 2024 06:34Good morning, pin assignment for the ignitor, hope this helps, courtesy of the classic forum, using on 650 and 900 good luck
Z1A AND 81 650
13 Jan 2024 14:10Hi members!
But now I'm installing a Mo.Unitt bluetooth on my bike I do run into a couple of problems connecting the reg-rec and ignition and I hope some of you can give me some guidance or advice.
1x Brown-White IGNITION LIVE (ALSO FEEDS BRAKE LIGHT SWITCHES ETC) FROM "JUCTION BOX"
1x Yellow-Black. GROUND
1x Black COIL TRIGGER WIRE (GREEN AND BLACK ARE THE TRIGGERS FOR THE TWO COILS)
1x Yellow-Black GROUND
1x Black-white IGNITION LIVE FROM JUNCTION BOX (CONTROLLED BY NEUTRAL LGHT AND SIDE STAND SWITCH)
Any help is greatly appreciated!
- Erikwolf22
14 Jan 2024 11:08 - 14 Jan 2024 11:28
Everybody thanks for your help and response! With the tips above I think I've figured it out, see below the updated connections. If anybody sees a wrong connection please let me know
Last edit: 14 Jan 2024 11:28 by Wookie58.
