break light blow out!!
  • steveo_4192003
  • steveo_4192003's Avatar Topic Author
  • 77kz650b-1
14 Jul 2006 12:36
#61977
my break light keeps going out! the tail light still works , but no break light!and i have replaced three times already!
i checked conections, bulb type,bulb fitting in socket
any ideas why?
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
  • mariozappa
  • mariozappa's Avatar
Re: break light blow out!!
14 Jul 2006 12:45
#61982
When you checked the connections, did you trace your brake light wire all the way back to make sure it's not grounding out against the frame or some piece of metal along the way?
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
14 Jul 2006 13:05
#61987
Sounds like a dead short to ground somewhere in rear brake light circuit.
  • trippivot
  • trippivot's Avatar
15 Jul 2006 07:17
#62133
does the tail light assembly have a rubber dampener?
vibration kills the brake light element. it glows with more power and gets hotter than the running light so the coil of wire breaks easily.
