Blue and red wire .
  • Jokinarnya
  • Jokinarnya's Avatar Topic Author
Blue and red wire .
30 Oct 2023 09:14
#891120
I have a blue and red wire hanging under my bike next to the stand.
Am I right in thinking it's for the oil pressue sensor?
If so, does it just connect under the screw in the sensor.
If not, where do I put it?
TIA
1982 Kz550 LTD
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Blue and red wire .
30 Oct 2023 09:16
#891121
What model and year is your bike ?
  • jwfels
  • jwfels's Avatar
30 Oct 2023 11:03
#891130
quite common wire, oil pressure, if 900/1000 paired up in alternator wiring, which is near side stand, 650 is in ignition area on right side under cover
Z1A AND 81 650
  • Jokinarnya
30 Oct 2023 11:55
#891132
Its a 1982 kz550 c3, pribably should have mentioned that initially.
1982 Kz550 LTD
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
30 Oct 2023 13:18 - 30 Oct 2023 13:19
#891133
Yes, the color matches the Oil Sensor switch wire color code...........and yes, normally i'ts got a felmale plug to go into the sensor, and that's it.     The ground is the sensor body and the engine.    It should work if the sensor is OK
Last edit: 30 Oct 2023 13:19 by hugo.
  • Jokinarnya
30 Oct 2023 13:56
#891134
The connection I can see isn't a plug. I don't know the correct name for it, buts a circular connector with a bit cut out, not dissimilar to a circlip shape.
it's obviously been clipped onto or around something at some point, I judt dont know what.
1982 Kz550 LTD
  • TexasKZ
  • TexasKZ's Avatar
30 Oct 2023 20:08
#891141
Yes, the blue/red is the oil pressure sender wire and it should go under the screw on the sending unit.
Here is a color wiring diagram.   www.kzrider.com/filebase?task=download.send&id=281&catid=62&m=0
here is the factory service manual, though the wiring diagrams are sadly black and white.   www.kzrider.com/modules/ServiceManuals/Kz400500550_79to83.pdf
  • martin_csr
  • martin_csr's Avatar
31 Oct 2023 05:19 - 31 Oct 2023 05:22
#891146
Fork terminal or fork spade terminal.
KZ650 pic is just to show the terminal.
Last edit: 31 Oct 2023 05:22 by martin_csr.
The following user(s) said Thank You: Jokinarnya
