Hi-beam and Lamp warning indicator lamps flickers after fuse box replacement
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
21 Oct 2023 02:16
#890728
Brand new Sylvania installed and brand new battery
Simple fuse box replacement, right?
I did only one fuse at a time for the sake of keeping it simple and saving myself "the mysterious wire" headache lol
All seemed to go smooth, when completed. It fired up, but now my headlamp, 'high-beam', and 'lamp' indicator lamps flicker, ..flickering gets worse with any throttle given.
Any of you have any idea what I could've possibly done to cause this symptom?
1982 KZ1100D1
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Hi-beam and Lamp warning indicator lamps flickers after fuse box replacement
21 Oct 2023 03:43 - 21 Oct 2023 04:22
#890730
Loose connection, increase in revs increases the vibration and connection make/break.
Could be either a terminal connection or if still on glass fuses a dodgy connection in the fuse. Glass fuses are Chinese made these days and shit quality.
Last edit: 21 Oct 2023 04:22 by Warren3200gt.
The following user(s) said Thank You: Gdailey2112, Wookie58
  • Gdailey2112
  • 82 KZ1100D1
21 Oct 2023 06:51
#890736
Went out this morning and checked the clamping ability on the three headlamp connectors and found one that was downright gapped out. Problem solved and once again you Warren had the answer. Thanks man!
1982 KZ1100D1
The following user(s) said Thank You: Warren3200gt
