Spark Plug Defect?
- daveo
Spark Plug Defect?
18 Oct 2023 10:31 - 18 Oct 2023 10:47
The ceramic post on one spark plug easily spins around on the body. There are no other visible irregularities.
Should the spark plug be used, or rejected as defective?
Short video below:
photos.app.goo.gl/vtzhU9eKyA96jLKP9
Short video below:
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 18 Oct 2023 10:47 by daveo.
Re: Spark Plug Defect?
18 Oct 2023 11:25
Looks bad to me. I'm no expert, though.
One thing, those plugs are resistor type, so be sure that you are not using resistor plug caps or resistor wires when running them.
18 Oct 2023 11:39
I suspect you will loose compression through there and it may even blow the centre out if you get excited, should be "crimped" tight
- sf4t7
18 Oct 2023 11:39
In 45 years, never seen the ceramic spin like that. Throw it away.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- Nerdy
18 Oct 2023 13:34
I would ask the manufacturer: they should be able to tell you for sure.
If it's wrong/defective, they might also want to investigate if it's a one-off or if there was a bad batch.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
The following user(s) said Thank You: slmjim+Z1BEBE, daveo
- Kelly E
18 Oct 2023 14:33
Could also be a counterfeit plug.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
The following user(s) said Thank You: slmjim+Z1BEBE, daveo, Wookie58
18 Oct 2023 16:02
I would want my money back.
