Positive battery terminal/starter relay?
- Brmercado
03 Oct 2023 11:37
I replaced my positive battery terminal on what I believe is the starter relay and can’t remember the order of these connections...
- gd4now
- Denco where did you go?
Re: Positive battery terminal/starter relay?
03 Oct 2023 13:14
It would help us to offer suggestions if you had mentioned what bike / model you are working on. I might suggest you add it to the sig area. I did take a look at other posts you made and in them you are working on a 81 440 D2. I have a wiring pic for a D1 but not a D2. I do not know if there are diff between the 2 years or not.
But here it is.
But here it is.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- Originalretro
03 Oct 2023 13:48
What a pity you took pics after and not before pulling it to bits
- Brmercado
03 Oct 2023 18:31 - 03 Oct 2023 19:19
The bike is an 81 kz440d1 ltd belt model. i don’t have much info about it as it doesn’t have a title. I’ll take any photo references you guys offer.
Last edit: 03 Oct 2023 19:19 by Brmercado.
- Brmercado
03 Oct 2023 22:30
I tried to download the pdf and it read me an error message, is there any way I could use a voltage tester or multimeter?
04 Oct 2023 05:12 - 04 Oct 2023 08:24
The KZ400.com site has the factory service manual. click the "here" on the right. you'll know what I'm talking about when you get there.
I just now downloaded it, so the link does work.
Warning: do not go into the forums there as doing so may harm your computer >> malware or whatever.
Last edit: 04 Oct 2023 08:24 by martin_csr.
- gd4now
04 Oct 2023 08:03
1977 KZ650 B1
- Brmercado
04 Oct 2023 13:36
Thanks a lot. I think I got it, unless the open ended side of the connector is what’s in the diagram. I have the rectifier connection on bottom and the ignition connection on top, I’m going to try and solder the frayed wire as well.
- gd4now
04 Oct 2023 15:56
Keep in mind that the wiring diag is for a D1 and you have a D2. There may well be differences between the 2 years I do not know.
1977 KZ650 B1
- Brmercado
04 Oct 2023 21:38
I have no idea, I’ll see when I get my battery and ignition. Both terminals are replaced and from different models that I soldered to old terminal pieces. I’ll keep posted
