KZ440 weird wiring
  • Brokolicka
  • Brokolicka's Avatar Topic Author
KZ440 weird wiring
30 Sep 2023 06:03 - 30 Sep 2023 06:29
#889915
Hi, I am trying to fix up a KZ440 Belt drive but im having problem with some wiring. I dont know if previous owner changed it or its some kind of special thing for West german model but none of the wiring diagrams fits the wiring on my bike 1. IC igniter has 6 wire coming in. The diagram shows 5, the Br/W is extra2. The extra Br/W from IC igniter then splits into 3 Br/W and together with green wires coming from Starter motor and red wire coming from thingy (pic3, thingy has B/Y coming from left handlebar switch) come into Six pin into this black thing with number "39" which i cannot pull off3. Front brake light switch has Brown and Red-Blue wire coming  into 6-Pin together with wires from Headlight switch wires. Which also isnt corresponding with the diagramAny help will be appreciated greatlyThank you
1982 - KZ440 LTD Belt drive
Last edit: 30 Sep 2023 06:29 by Brokolicka.
  • Nessism
  • Nessism's Avatar
  • Away
Re: KZ440 weird wiring
30 Sep 2023 06:23
#889916
Please modify your post before the edit time period expires, by clicking "insert all" next to your photos.  That way the photos will actually show up and be readable.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Moderator
30 Sep 2023 06:31
#889917
Awesome  Ed
Thanks
