1977 Kawasaki 1000A wiring colors
- macs custom
20 Sep 2023 19:49
So hello to everyone.
i purchased a 1977 Kawasaki Kz1000A and it came with a right side handlebar switch for a 900 so the wire colors are different.
The SWITCH wiring is yellow with red stripe, red, black, tan, blue with red strip and solid blue.
I've taken the switch apart to see that The tan wire and yellow/red wire goes to off and on engine stop
The blue, blue and red strip and tan goes to middle On-PO-off switch
The black wire and yellow/red stripe goes to the starter button.
The colors of the wires on bikes main harness are Yellow with red stripe. brown with white stripe. Blue with white stripe 2 solid brown wires and Black
I do have a book but unfort- my vision is not all that great. I'm hoping someone can match the wires up for me! Any help match these up is GREATLY APPRECIATED
I can also be emailed at macs.custom@yahoo.com
Re: 1977 Kawasaki 1000A wiring colors
21 Sep 2023 12:48
Welcome to KZRider
I'm sure a member will be able to help you with your wiring issues .
Your next post needs to be in our new member section to introduce yourself to us
22 Sep 2023 01:11The below should sort you out, if not I will need to see pictures of the inside of the switch. Let me know how you get onSo hello to everyone.
22 Sep 2023 04:28
If your vision is so poor that you cannot read the book, how are you able to read these posts?
22 Sep 2023 05:43 - 22 Sep 2023 05:44
Just in case: there's a digital copy of the KZ1000-A1 wiring diagram which can then be enlarged. It might be linked here on KZR.
Also, the manuals I've seen list the wire colors of the various circuits in the body of the manual. reading glasses might help.
Last edit: 22 Sep 2023 05:44 by martin_csr.
