Blk/yel that went to the IC was left hanging
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
22 Aug 2023 19:03
#888593
After ds2-1 install seems all wires had a home except the blk/yel, if the IC has been removed should this wire then be connected to the frame or grounded?
1982 KZ1100D1
  • hardrockminer
  • hardrockminer's Avatar
Re: Blk/yel that went to the IC was left hanging
22 Aug 2023 20:06
#888594
Black/Yellow is a ground wire.  Where is it attached?
You should have only 3 wires from your DS2-1.  A black, a green and a red.  The first two go to your coils and the red connects to a power source.
The following user(s) said Thank You: Warren3200gt, Gdailey2112
  • Gdailey2112
  • 82 KZ1100D1
22 Aug 2023 23:56
#888596
It'd originally went to the stock IC unit on the bat box, the three you mention are hooked up as they have been, the blk/yel was left hanging. I simply connected it to the frame via a starter solenoid bolt.
1982 KZ1100D1
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
23 Aug 2023 00:28
#888597
It didn't need to go anywhere ( could have been taped to the loom and left) however adding a ground point to the main ground line (which is what you have done) can't do any harm and probably has improved the grounding of the main black/yellow line
  • Gdailey2112
  • 82 KZ1100D1
23 Aug 2023 10:47
#888613
Took care of the jumpy tach
1982 KZ1100D1
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
26 Aug 2023 19:27 - 26 Aug 2023 19:36
#888722
Remembered the following post back in April.  Possibly the same wire:
www.kzrider.com/forum/4-electrical/61879...as-been-jumpy#883375
BTW, how is your generator rotor working?  I still have one boxed up for you...
1982 KZ1100-A2/1170cc sleeper 😀
Last edit: 26 Aug 2023 19:36 by daveo.
  • Gdailey2112
  • 82 KZ1100D1
01 Sep 2023 00:26
#888906
Hey Daveo! It's working but missing a small chunk of magnet, currently sorting through wiring using the wookies methods and process of elimination, 90 ohms in one wire under tank   soldered new wire in, now .02 ohms   gonna keep checking.
Finances are a just a lil light atm,   ..it's very frustrating as it's the one thing always holding me down.
Hell, I really don't know how much longer I'll be able to tinker as my hands give me very much grief.
1982 KZ1100D1
The following user(s) said Thank You: daveo, Wookie58
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
01 Sep 2023 08:57
#888920
I used to have problems with my hands and then I started taking glucosamine daily. Considering the fact that I have broken all of my fingers on both hands several times each I can still work blind with small hardware in tight spaces. The glucosamine has given me back my dexterity, I've been taking it for at least 15 years now.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
The following user(s) said Thank You: Gdailey2112
  • Gdailey2112
  • 82 KZ1100D1
03 Sep 2023 06:46
#888967
How long did it take to get dexterity back. I have zero cartilage in both my thumb joints. Painful is understated
1982 KZ1100D1
  • Kelly E
  • Kelly E's Avatar
03 Sep 2023 07:57
#888969
It was at least a month before it started to make a difference.
1983 Honda CB 1100F
And more
