Strange wiring to coils
  • TexasKZ
  • TexasKZ's Avatar
  • Away
Re: Strange wiring to coils
15 Aug 2023 04:50 - 15 Aug 2023 04:52
#888274
Last edit: 15 Aug 2023 04:52 by TexasKZ.
The following user(s) said Thank You: Rolf1976_KZ900
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
15 Aug 2023 15:19
#888305
That is exactly it   it sometimes helps to think of "voltage" as "pressure" so checking "system pressure" is done on a complete and functioning system
  • hardrockminer
  • hardrockminer's Avatar
16 Aug 2023 05:40
#888318
I think of voltage as energy potential.  An analagous situation would be the height of a waterfall.  Higher height means more potential energy at the top of the fall compared tot the bottom.  I think of current as flow.  The analagous situation would be river flow.  More flow means more current.
The following user(s) said Thank You: Wookie58, Rolf1976_KZ900
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
16 Aug 2023 05:46
#888320
This makes it quite easy to visualise
The following user(s) said Thank You: sf4t7, Rolf1976_KZ900
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar Topic Author
16 Aug 2023 11:44
#888328
Ha Ha Ha Thanks for helping ,well i got another electrical mystery i need help with i post that in another tread.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
16 Aug 2023 12:30
#888331
No worries
