KZ440 timing advancer
  • Kzrider1980
  • Kzrider1980's Avatar Topic Author
03 Aug 2023 17:37 - 04 Aug 2023 07:20
#887916
Pertaining to the timing advancer mechanism off a '83 KZ440D5 . . .
While cleaning and refurbishing this advancer (it was a solid block of rust) I mistakenly lost the "insert(s)" that fit into the notches on the weights (I hope my terminology is correct lol).
Is there a way to replace the lost inserts? What material are they? Phenolic? Metal?
Thanks in advance.
1980 KZ750E1
1983 KZ440 LTD D5
Last edit: 04 Aug 2023 07:20 by Kzrider1980.
  • martin_csr
  • martin_csr's Avatar
Re: KZ440 timing advancer
05 Aug 2023 07:03
#887970
From a post by loudhvx the little pads are rubber and when missing the timing can be off. you'd need to check the timing with a timing/strobe light. His comment was in regards to a 550 but I would assume it would be the same thing w any KZ timing advancer.
The following user(s) said Thank You: Kzrider1980
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
05 Aug 2023 12:47
#887982
I would try to use 2 - 3 ring layer of shrink tube to mimic the rubber damper pads.
