79 kz400h tail light not working
- ckahleer
03 Aug 2023 12:38
Brake light works fine. I can lift the seat and apply power to the to the tail light connector and the tail light will light.
I have a 74 - 77 service manual, but wiring may be different on a 79.
Can someone share a 79 wiring diagram? Thanks
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
Re: 79 kz400h tail light not working
03 Aug 2023 15:10
It´s the same wiring, red wire (tail light) get power by the ignition switch in park position (white wire battery) and blue wire in ignition on position (switch internal connected).
- ckahleer
04 Aug 2023 19:17
The problem turned out to be within the ignition switch. To fix, I jumpered the the brown wire (which is hot when ignition is on) to the red tail light wire. I never use the "park" position any way.
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
05 Aug 2023 06:53 - 05 Aug 2023 06:54
Did you investigate the soldered connections inside the ignition switch? You might be able to fix the problem.
Last edit: 05 Aug 2023 06:54 by martin_csr.
