Spark plugs
  • Trasho420!
  • Trasho420!'s Avatar Topic Author
Spark plugs
03 Aug 2023 09:49
#887896
I have a 1980 kz1000a.  Should I use copper, platinum or iridium spark Plugs?
  • Nessism
  • Nessism's Avatar
  • Away
Re: Spark plugs
03 Aug 2023 10:28
#887900
Use non resistor NGK or ND plugs.  I think these may be denoted "copper" but that detail doesn't matter.
NGK B8ES
ND X24ES or X24ES-U
Don't use plugs with an "R" in the designation, because that indicates "resistor."
  • zed1015
  • zed1015's Avatar
Re: Spark plugs
03 Aug 2023 12:20
#887903
As above.
It doesn't need anything fancy.
NGK B8ES or the equivalent for a stock machine.
  • Gdailey2112
  • Gdailey2112's Avatar
  • 82 KZ1100D1
Re: Spark plugs
18 Aug 2023 13:45
#888465
I thought we're supposed to have resistance somewhere be it a plug, a cap, but not both?
1982 KZ1100D1
  • zed1015
  • zed1015's Avatar
Re: Spark plugs
18 Aug 2023 14:13
#888466
At the most you have only one source of resistance be it the plug , cap or lead.
At the least you don't need any form of resistance if you don't have any electrical components that may be affected and the neighbours don't figure out why the tv keeps going fuzzy when you ride by.
The following user(s) said Thank You: sf4t7, Gdailey2112
