Bike died
- Joniplayer1
- Z750 b1 owner and rd 350lc
Bike died
30 Jul 2023 00:35
Hi was riding my 76 b1 yesterday and hit the lights on and it suddenly died , kicked and kicked it but would not start any ideas appreciated.
Re: Bike died
30 Jul 2023 00:58
Have you checked the basics first (battery terminals, fuses &a earths) ?
- Joniplayer1
Re: Bike died
30 Jul 2023 01:12
Hi , yes all fuses seem OK, well the ones under the side panel, is there another?
Re: Bike died
30 Jul 2023 02:03
Not sure, you could check the wiring diagram. It sounds like a connection issue in the ignition circuit (when you switched the lights on it put additional load on the circuit) what is the battery voltage and what is the voltage at the coil positive terminal with the ignition and and kill switch set to run (should be no more than 0.5v difference between the two readings) ?
- Joniplayer1
Re: Bike died
30 Jul 2023 02:19
I'll need to get a voltage meter , was hoping it was a simple fix like a fuse .
Re: Bike died
30 Jul 2023 03:42
Does your headlight come on when you turn the ignition key? Why are you kick starting it? Is there a problem with the electric starter?
Take your tank off and check the plug connections, pay close attention to the one that connects your ignition to the main circuit.
Re: Bike died
30 Jul 2023 05:48 - 30 Jul 2023 06:03
I would swap in new fuses as a just in case. Assuming you have the stock-type glass fuses, sometimes a fuse can appear good but the fuse wire between the end caps can be separated from one of the caps. I've never seen this, but apparently it's a thing.
ps: be sure to use the correct size fuses. i.e., correct amps. the stock fuse box may have a label or it could be embossed with the info.
Last edit: 30 Jul 2023 06:03 by martin_csr.
- F64
- 81-KZ440D2
Re: Bike died
30 Jul 2023 08:21
It very well could be a simple fix.
Get a meter if you can.
81-KZ440-D2.
LIC, NY
LIC, NY
- gd4now
- Denco where did you go?
Re: Bike died
30 Jul 2023 12:07 - 30 Jul 2023 12:08
If I remember correctly there were several B1 models from 1976 (KE175 B1, KZ750 twin B1, KZ 900 LTD B1) there may be others. Which model are you talking about as the 3 mentioned all have somewhat different electrical systems/wiring. Knowing which may help us to provide more useful information/tests for you.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 30 Jul 2023 12:08 by gd4now.
Re: Bike died
30 Jul 2023 14:16
His bio says it's a 750. It also says he has an Elsie! What a great bike!
The following user(s) said Thank You: Joniplayer1
- gd4now
Re: Bike died
30 Jul 2023 14:33
Sorry did not look at that carry on!
1977 KZ650 B1
Re: Bike died
30 Jul 2023 15:48Could't agree more, the majority of electrical issues with these old bikes is down to corrosion causing resistance faults which manifest as "Volt drop" you can only effectively diagnose these issues with a voltmeter. For a small outlay (maybe £25) you will save yourself days of heartacheIt very well could be a simple fix.
