81 kz750 ltd wiring nightmare
- oldkaws4ever
- Have no regrets...... You only live once.
24 Jul 2023 12:59
I just picked up this 81 kz750 Ltd and the wiring is horrible and I am not good with diagnosing wiring. Can someone help me as far as what needs to be connected. There are splice’s everywhere. Thank you in advance.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- gd4now
- Denco where did you go?
Re: 81 kz750 ltd wiring nightmare
24 Jul 2023 13:18 - 24 Jul 2023 13:19
Looks like you have some wire tracing to do. You have a VOM or test light or? Not sure if this will help as you may have one already, but here is a wiring diag for the KZ750-H2 LTD
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 24 Jul 2023 13:19 by gd4now.
24 Jul 2023 13:45 - 24 Jul 2023 13:49
The KZ750L3 page below has wiring diagrams. scroll down and click The Bible link.
Some of the Ltd diagram years are wrong. 1981 is the H2 and 1982 is the H3. So it should be 81 H2 & 82 H3.
kz.bike-night.com/
kz.bike-night.com/
Last edit: 24 Jul 2023 13:49 by martin_csr.
24 Jul 2023 13:52 - 24 Jul 2023 13:53
Oh boy you have your work cut out with this, as an "aside" if you are fixing bikes (or cars) for a living and elec diag isn't your thing you might find my "fault finding guide" useful on the below link
kzrider.com/forum/forum-index/faq-wiki/6...-fault-finding-guide
There are so many things obviously wrong with this bike (not least all the green corrosion which will cause voltage drop issues) at first glace
The White and White/Red joined with a screw cap - this is not a recognised termination method for automotive use and there should be a 20amp fuse between these two wires. This is the main supply to the ign switch so without a fuse any short circuit is a potential fire !!
It looks like the main starter lead is disconnected from the solenoid but in the first picture the main ground looks like it has been cooked - this may be because the engine ground is bad, if so when the starter was operated the ground wire in the first pic would have gone up in smoke as it's not up to carrying starter current
The yellow/red that is hanging is the supply to the coils from the kill switch
To be honest given the amount of butchering and the level of green corrosion you would be best trying to source another loom that is intact. If you decide to persevere I would strongly connecting your battery with "jumper cables" so you can snatch them off if it starts smoking !!!!!!!
Last edit: 24 Jul 2023 13:53 by Wookie58.
The following user(s) said Thank You: oldkaws4ever
- oldkaws4ever
24 Jul 2023 14:40
I’ve spent the last hour trying to make sense of this bubba-fied wiring someone did. I’m pretty sure I have it all pretty much figured out. I’m just taking my time trying to sort it out. Here is the freaking positive battery cable that was on it.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
24 Jul 2023 18:46
- oldkaws4ever
24 Jul 2023 19:54
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
25 Jul 2023 01:19
If you are going to repair this mess (I had a quick look on ebay and the replacement looms on there don't look great !!) then you need to approach it in a logical and methodical way or you will spend several days going out of your mind "chasing your tail" I would suggest the following before connecting a battery to it
- Sort the main battery lead to the solenoid - the main lead from the solenoid to the starter - main battery ground to the engine casing
- Sort battery supply to the fuse box
- sort the supply from the fuse-box to the ignition switch
- Sort the generator and regulator/rectifier wiring
25 Jul 2023 08:26 - 25 Jul 2023 08:43
CycleTerminal, VintageConnections & Z1Enterprises have electrical supplies. You should get the correct terminal pins & stuff and a good ratcheting open barrel crimper for doing stock-type crimps. Terminal pin extractor tools are handy as well (instead of using a paper clip). cycleterminal has a nice set. I already had a HF crimper but the dies were wrong, so I got a correct set of dies from Aircraft Tool supply. the total cost was the same as getting the correct crimper in the first place. doh. Z1Enterprises has color wire and maybe also VintageConnections.
At CycleTerminal some of the Sumitomo 250 & Hitachi .110 connectors are the same as stock. Be sure to get extra terminal pins for practice or in case you mess up. At the bottom of the terminal page there are waterproof bullet sets that are pretty nice, handy for fixing that nice splice in the pic. hee.
Last edit: 25 Jul 2023 08:43 by martin_csr.
The following user(s) said Thank You: oldkaws4ever, Wookie58
