Where/how to start diagnosing electrical issues
- SirCanucklehead
Re: Where/how to start diagnosing electrical issues
08 Jun 2024 16:28Welp, I went out there to do some work with the intention of going through this procedure. However, a few parts I had ordered a while back showed up, including one of the 3 relays on the right hand side of the bike (part #27002-1051). I swapped this out, turned the bike on, was about to go through your procedure. Then, just for giggles, I decided to see if it turned over, and to my absolute shock/delight, it did. I do still intend to go through these steps, but this was such a surprise that I decided to just call it a day on this incredibly high note.Thanks for the schematic. I couldn't find anything on my end..
Grab your meter
Meter on DC V
Ignition key ON
Kill switch set to RUN
black probe on negative battery post
red probe on positive battery post
note voltage
Going to the teal square at the top.
You have a 6 wire connector
move your red probe and backprobe (do not disconnect the connector) all of the wires and note the color and the voltage.
You may need a paper clip, nail, t-pin to be able to backprobe the wires.
Go to the ignition coils (red squares).
Backprobe each wire at the coils and note voltage
Move your red probe to the safety switch---should be at the clutch.
Back probe each black wire while pulling in the clutch and pressing the starter button.
note voltage
I'll have you check the pink box after I see the results of the clutch switch.
turn off bike
Also, I hugely appreciate you taking the time to write these two guides out for me. You've helped me learn some solid electrical testing procedures, and without that I never would have known my fuse connection was bad, let alone how to even test for it.
1984 KZ550 LTD Shaft
The following user(s) said Thank You: F64
- F64
- 81-KZ440D2
08 Jun 2024 17:03
Good Job!!
Have fun riding it
Have fun riding it
81-KZ440-D2.
LIC, NY
LIC, NY
