Different resistance readings on coils
- Aragone79
28 May 2023 09:08
So I got a set of coils off eBay and they came with 3 spark plug wires. 2 accel wires and 1 little thicker summit racing wire. I put all my old caps on and used 1 of my old wires. Well the one with the old wire and accel wire reads 12k ohms on the secondary and the one with 1 accel wire and 1 summit wire reads 22k ohms on secondary. Is it ok to run them like this? Is it the wires making a difference or maybe bad cap? Thanks for any help!
- F64
- 81-KZ440D2
Re: Different resistance readings on coils
28 May 2023 09:43
Can you pull the wires and just measure the wires' resistance?
Your wires may be different resistances.
Measure the caps separately.
Measure the coils secondaries without the wires.
81-KZ440-D2.
LIC, NY
LIC, NY
The following user(s) said Thank You: Aragone79
